A new tool to Grease Front 4x4 Hub Bearings
#76
on
Hubs not locked.
Yes, how does packing the grease in the unit-bearing hub affect ABS function and vacuum function also? Vacuum is not sucking through the grease, I assume.
Are you auto-hub guys getting vacuum function with greased-packed sealed unit-bearing hubs?
RTFLDGR
RTFLDGR
#77
#78
on
I think I am answering this for myself: Vacuum does not pass through the inner-hub area and large bearings we are greasing through the ABS hole.
Vacuum passes through the hub via a passage into the lockers.
I cannot visualize 10hg of vacuum sucking through packed-grease.
#81
"If that was a problem they wouldn't work when they were new." EXv10 quote
It would appear (though we can't see it) that the sealed unit-bearing assembly is not heavily greased, from the factory. I can understand how vacuum could suck through a lightly-greased assembly. Yet, we are PACKING grease in this hub. Vacuum cannot suck through packed grease without sucking the grease up into the vacuum port, I believe.
Like the other guys said it would, the ABS-sensor came right out, and grease went right down that access-hole. A LOT of grease. I used some old oil-gauge tubing and the brass hardware that went with it (scrap-stuff) to down-size the grease gun hose. Then you gotta hold your finger over the ABS-hole while pumping the grease to really get it to pack down in there. It was about 60 pumps and then the grease was forcing back-out. I cleaned the ABS-hole out with a Q-tip and closed it up.
After reassembly, we road-tripped the 2005 F250 several hundred miles. It worked very well. :-)
Thank you, fellow Ford men for the advice. The hub-greasing gives a bit more peace-of-mind.
RTFLDGR
RTFLDGR
sammie0126
08-20-2014 06:06 PM
78 PEB
24
03-31-2014 06:53 AM
sammie0126
03-07-2014 04:40 AM
tasboj
19
01-21-2013 07:28 PM
