2010 King Ranch 6,400 mi found on road dead
#61
Both of you are right. I worked on one not too long ago that kept dying when the tank got low. Turned out the sending unit has a valve roughly 2" above the bottom of the sending unit. This valve popped out of the piping. When the fuel level got low enough, it was sucking air through the remaining hole (effectively, out of fuel). Even though there was 1/4 tank left. Bad sending unit. I have also replaced high pressure pumps for exactly what you experienced.
#63
#64
I was thinking the same thing when I first started reading this thread. Sounds like a bit more is involved from further reading.
#65
If we assume that the MTE indication was even within 10 miles of correct, there was so little fuel in the tank that the pickup would be sucking air under hard braking or acceleration. Low enough to be sucking air meets my definition of running the truck out of fuel.
It's fortunate that Ford is fixing the HPFP and downstream damage, which may or may not be related to sucking air into the fuel system. Certainly sucking air into a hydraulic pump operating at a measly 2,500 PSI is well known to damage them, the HPFP in these trucks operates up to 26,000 PSI so I have not doubt that sucking air into the HPFP has a good chance of damaging it. Hopefully the OP will ensure he doesn't run his fuel tank low enough again to ever test the theory.
#66
#67
#68
#69
The problem with trouble shooting these types of problems is that the original posting caused a narrow view--an anchor of opinion--as to what caused the problem; That is, the low miles to empty as indicated on the gauge. In fact, the low mileage could be (and looks like) a mere coincidence to the real problem. To me, the disturbing element of this posting is the knee-jerk reaction, and that the OP felt it necessary to shout their disappointment on at least one other forum (now closed by moderator--thank you--:2010 Ford F-250 King Ranch with 6,400mi found on road dead....). Look, for anyone who is disappointed with their 6.4l truck, then for heaven's sake sell it. But please let me enjoy my truck, and the good technical advise of this forum, without the (opinion) unnecessary Ford bashing and how the problem effects your lot in life. Sorry, I just don't see the need to go down the bashing route. Gee, I feel like Simon Cowell.
#70
Correct me if I am wrong, but doesn't the 6.4 use the same CP3 hpfp as the other common rail diesels (cummins,duramax)?
At least the OP gets 13 mpg, my buddies '09 2500hd w/ duramax gets 12-14mpg, and it has all of the dpf/doc stuff removed and tuned out. He also get 8 mpg towing his 5er, and has had the hpfp go out, and had to tow back from Glamis in limp mode because the Allison freaked out. But the trucks does have some miles on it, around 40k, lol. All of the emissions diesel are super sensative to everything, fuel, trash, weather, gone are the days of fueling them with mexican diesel, and just draining the water seperator every fillup. Conversely, they have a ton more power and refinement now. Bottom line, they will all continue to have problems as long as the Govt. continues to demmand what we have to build/buy, as was mentioned, the same things happened to gas motors in the 70-80's, it will all work out.
#71
Hence why the forum is here to try to get info on the problems. If you really wanted to just "Enjoy" your truck for what it is, I would just stay away from forums completely. That way you could enjoy it and love it unconditionally, not caring about what faults it may have or how to correct or make the truck better. You would not actually see your truck for what it really is, but who cares, you would enjoy it.
Some of us want to actually get to know the truck a little better. If my HPFP goes out at 6,400mi I would like to know if this has happened to anyone else. Is it a common problem and so forth, hence a forum.....
I have already apologized for bashing the 6.4. I was FRUSTRATED. I would like to move on to the technical side of this situation now. And by the way, I love the Heartland site.
Grey
#72
"They are going to take some fuel samples for Ford, which I am sure is to try to [Removed by Max] me out of a warranty by saying I put bad fuel in it."
Anyway, I appreciate your frustration and desire to vent. I sometimes vent and then don't push the "send" button. You're right, the overall outcome has been important as technical reference.
#73
I'm with crazy oo1. This thread has gotten way outta hand and maybe started out that way. I apologize for my part in that. There is some good info here, but there's a bunch of stuff that's not worth the keyboard it's written on. Let's just be happy that all seems to be turning out OK, bury it, and let it rest in peace.
#74
Hi Senix, what does that mean? Are you speaking of something like a limp mode? If so, when does it kick in? I don't know how the guys with stock tanks ever get anywhere given the mileage we get, I have a 60 gallon tank and can't get in a good day of towing without stopping for fuel. I have no idea how low my tank is when the 50 MTE lights up but I've been down to under 20 or so and it was very uncomfortable. I use the mileage and MPG meter (compensated for error of course) to figure mine and I'm usually pretty close. Still, it would be nice to know the fuel warnings were accurate.
