49 truck with 4.6 modular motor-IT'S ALIVE!!!
#241
#242
I've been back and forth on whether to use a tilt front-end or try and repair some pretty bad fenders and hood. I've finally decided on the tilt front-end.
It got pretty dirty sitting around all this time so I used a degreaser then dawn soap and some comet cleanser on the underside. I'm using some conduit and duraglas to strengthen it for use with a linear actuator.
Here's the first piece of reinforcement I made today. I filled the conduit with sand to keep it from collapsing then bent it with this bender I rigged up.
This is actually two pieces of 1/2" EMT conduit. I ground the coating off on the end and welded together. The coating is toxic when welding so care must be taken. I welded next to an open overhead door with a respirator on. I laid a few tacks and walked away for a few seconds then repeated.
I roughed up the conduit with 40 grit on a roloc then followed with some 36 grit by hand. I've also cut some grooves in it on top and bottom side to help the Duraglas bite some more. I sanded the fiberglass with 36 grit by hand and used a pick to scar up the surface as well.
I still have to weld the top piece(it's on the bottom here) of the mount on. I'm also going to add a couple of braces from the mount to the halo support I made.
The Duraglas should be here by this weekend.
#243
#244
Well, another change of plans. I tried to get on board with making this a tilt front end but it just wasn't meant to be. I think it would be kinda cool but it just didn't excite me enough to put in the work involved to make it happen. I always wanted stationery fenders, grill, etc. with a tilt hood. So I'm trying to make it happen with fiberglass unit. I took the sawzall to it yesterday so no turning back.
I will extend the fenders inward with some fiberglass, the hood needs some work as well, the fenders where they meet the cab also.
#245
#246
#248
Thanks Jeff and Nicolle.
Getting around to some detail work. It's tedious but needs to be finished.
I ground down the welds on the bed rails and inside of tailgate top rail.
BEFORE
AFTER
The teardrop on the corners of the bed was to flimsy so I boxed it in.
BEFORE
Four pieces shaped to box it in.
AFTER
BEFORE
AFTER
BEFORE
AFTER
#250
Thank you. Small, tedious work that has to get done but can sometimes cause burnout when you don't see "big" stuff getting finished.
I didn't have a wide enough piece of metal when I made the bedsides to go all the way down to the running board and I didn't want a bolt on filler piece so I'm welding in a piece. Got the passenger side finished tonight. I plan on making the running boards on down the road.
#251
Finished extending the bedside on the drivers side. I had an issue with the bedside previously when I was welding the fender on. I had some extreme oil canning. I used a stud gun then and eliminated the oil canning but there was still a really high spot that I never addressed.
Instead of trying to keep shrinking areas I just cut some slits in the trouble spot, straightened the metal and welded back. Probably took an hour or more to weld back. I laid a few tacks, ground down with cutoff wheel then smoothed with roloc then repeat. It turned out great. The metal is straight and no oil canning.
#253
Well church got cancelled tonight because of snow and I got a little stir crazy sitting around so I at least put in an hour of tinkering. P/O butchered the dash filled with resin and mat.
I cut the hole a little more square. Tried to hammer the edges a little flatter and made a brace out of 1/8" steel to weld back in the middle. I put it in the vice and bent the edges for support to match the original brace.
Hopefully try to patch the sheetmetal this week.
