Ford actually made a MAF conversion kit for 1987-1996 F-150's?!?!?!?!
#46
#47
89f2urd....what a diversity of vehicles you have there.
'89 F2 4x4, dana50 TTB (love it), 5 spd- 5.0 w/ LT's, timing advanced to run on 89: for the dirt and joy ridin
'02 dodge 2500 6 spd cummins, 230k miles: 475/1000 rwhp/tq-for the street (yea ill race)
'00 SS camaro 6 spd, 405/390 rwhp/tq-for rippin
#49
just wondering, did you do any porting to it? from the looks of it, your truck was a MAF 302 from the factory (did you retain it)? and when you had your chip burnt, was it a mail-order chip? who did it? how'd they do? im just tryin to gather as much info as i can before i pull the trigger on a particular motor/computer setup for my build.
#50
No i didn't do any porting on the intake , my truck was factory MAF , i went to a 61mm dual bbk TB , and switched to a Pro M 80mm meter , i live in florida , had a mustang race shop burn a chip on the dyno , they just make dyno runs finding out what works best with timing curve , AF ratio , so on , if its an auto they can change and set shift points , line pressure , they also can change the rev and speedlimiters , and you can use a lower thermostate if you wan't , they do it with a tuner then burn it on to a chip , cost me 600 , but i think its worth ever penny....
#51
#52
#54
Very true...But just to establish a baseline, no complaints here...
Now, once the goodies start flowing, it'll start costing more for, as you said, TUNING....UGH...lol
Here's a quick list of things I'd LIKE to do, any input to better mate everthing up, will be appreciated...
-Port head-Gasket match Intake/Exhaust ports
-Bore cylinder walls 0.030"
-Shave head 0.010"
-Install Idle-4,500 RPM camshaft
-Enlarge Exhaust Manifold tubes to 1-3/4" pipe
-Install Cloyes Steel Adjustable Timing Gears
-Install either 1.6" or 1.7" Roller Rocker Arms
-Swap TB for a 5.0 TB
-Advance the crank timing 4*
-Advance the dizzy up to around 12-13*
Anymore ideas on this one Lew?
-Shave head 0.010"
#55
Sounds fine to me , i don't know much about the I 6 , i have had a few mustangs so its 302s for me , if you have a stick the tuning will be alot less , they won't need to work on the trans , the timing cure takes some time , my base timing is set at the stock 10 deg BTDC , its the amount of timing that changes though the rpm range that is contoled by the computer that they change that makes the big difference....Lew
#56
#57
#58
I was looking for 50-ish hp, at the rear wheels, where it counts
Also, It's a Superflow 903 Dyno....
Engine Dyno
Oh yeah, before I forget, sorry for the
Engine Dyno
#59
are they the ones buildin your motor? only reason i ask, they might not have a chassis dyno, but only the engine dyno you link'd up would mean you would have to take your motor to them. somethin you should look into. . .if they dont have it you wont be able to know what youre pickin up at the wheels.
also, different engine builders feel differently about new oils and "break ins". . .but i always like to break my motors in before i rip on them or slap them on a dyno.
señorEddie
06-07-2016 01:53 PM
camo86
05-24-2012 05:29 AM
1965F100
03-11-2011 01:17 PM
