Oil leak in 5.4 engine
I also have this problem of a oil leak. I have A 2003 f150 fx4 with the 5.4 triton motor. It is leaking on the passenger side all over the starter and down the bell housing of the trans. thought it was a rear main but was not. truck is paid off and no warranty. I notice oil last couple off changes I did myself. took it to a freind of mine we found out it was a head gaket leak. looked up the tbs found nothing. sound like ford needs to own up to there mistakes. know I have to fix there problem. But I could use some help with this problem. will I need to replace this head also.
oil leak on the 03 5.4 triton
it is on the passenger side right side at the rear of the motor. By putting in a new head gasket will this stop it. It has never over heated or could there be another problem. I am seeing oil in the tank were the coolant goes and a little white foam in the oil cap area but not in the oil pan. I am pretty certain it's a head gasket.
