Bronco II Ford Bronco II
Cat. converter....or no cat. converter...?
Old 01-28-2011, 03:43 AM
mdr617's Avatar
mdr617
mdr617 is offline
So, i have a 88 bronco II, 2.9 v-6. It has the two cats...I have a magnaflow direct fit cat. i plan on installing soon, but i am still a little curious. What happens if you run no cat besides causing global warming? I have seen something called "test pipes" offered for this, and they say "for racing use only". Do you really gain any HP or TQ from removing the cat? Like i said, i am installing a cat. converter, and i understand that it is illeagal to remove it, i am just curious what it would do without it.
Old 01-30-2011, 10:41 AM
Loud4.9's Avatar
Loud4.9
Loud4.9 is offline
I dont no the laws in the states but here in canada we can cut them off and run it without. My experince with cats they tend to get plugged up over the years and decrease gas mileage and power ive had a few vehicle took them off and they have run alot better and seen a slight bit better in gas consumption.
Old 02-04-2011, 01:30 PM
im2tall33's Avatar
im2tall33
im2tall33 is offline
hmm just have a question that goes along with this..if i remove my cat (87 bII 2.9) will i have to reprogram anything and or will it through the o2 sensors out of wack?
Old 02-04-2011, 07:08 PM
TheThickster's Avatar
TheThickster
TheThickster is offline
You could gain about 5-8 horsepower removing the converter but you will get alot louder and raspier exhaust if you have a performance muffler (flowmaster,magnaflow,dynomax,etc.). If its your daily driver id put the magnaflow cat on just to be safe you know how the law is. Magnaflow cats are very high flowing so youll barely notice any difference over a test pipe, plus you get a cleaner smelling exhaust and mellow sound with a performance muffler.
Old 02-04-2011, 07:11 PM
TheThickster
Nope on OBD1 systems it uses only one oxygen sensor which is before the cat.conv. The cat is not being monitored by the ECU
Old 02-06-2011, 08:34 PM
mdr617's Avatar
mdr617
mdr617 is offline
yeah, i did notice that my o2 sensor is before my cat also
Old 02-27-2011, 02:34 PM
boogaloo's Avatar
boogaloo
boogaloo is offline
Throw them away, just added weight.
chrislambing
1999 to 2016 Super Duty
05-25-2023 06:17 PM
jdadamsjr
10-09-2014 02:39 PM
unclehan
18
09-16-2004 02:04 PM
jwchatm
08-10-2002 05:08 AM
Quick Reply: Cat. converter....or no cat. converter...?
