Wiring diagram for fuel pump circuit ??
Old 01-26-2011, 01:22 AM
ex_cursion's Avatar
ex_cursion
ex_cursion is offline
Anyone have a wire diagram for the fuel pump (stock, HFCM) circuitry ? I am trying to troubleshoot no voltage to the pump and I need to know the flow between the relay, inertia switch, etc...Thanks in advance !!
Old 01-26-2011, 06:48 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Old 01-26-2011, 12:07 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
The first diagram below is 26-2 and shows the fuel pump circuits plus a few others. The second diagram is 26-1. I put it there because it is referenced in 26-2.
Old 01-26-2011, 12:12 PM
dchamberlain
I should mention that those diagrams are for a 2004. If your truck is NOT a 2002-2004, then the wire colors and connector numbers will probably be the same, but the fuse numbers will definitely be different.
Old 01-26-2011, 01:47 PM
ex_cursion's Avatar
ex_cursion
great guys,
Thanks so much, so it looks like the relay in the junction box is definitely before the inertia switch. So if I have power at the inertia switch it is safe to say that the relay is working. I must have a bad connection somewhere between the switch and the pump...
Old 01-26-2011, 06:22 PM
cheezit's Avatar
cheezit
cheezit is offline
take note of the fact the the relay for the fuel pump does not list pin numbers while the one for the heater does. the one without numbers is part of the module and can not be serviced.
Old 01-31-2011, 03:16 PM
ex_cursion's Avatar
ex_cursion
THANKS to everyone for their help...turns out that I screwed up and had the wrong connectors on the WIF sensor and pump . They will seat incorrectly even though they are keyed. I checked the voltage at each plug when first installing but hadn't realized that the inertia switch was tripped when I did. With the switch tripped, I saw some voltage at the black plug and nothing at the gray so had figured that there was low voltage to the pump and the WIF sensor was just an open or close switch. WRONG. Wiring diagrams with wire colors showed me where I went off track. Much better now...
wohurst
06-07-2015 09:55 AM
BURNSTOUGHFORD
40
03-27-2013 05:22 PM
Alterado
1999 to 2016 Super Duty
05-19-2011 07:46 PM
skookum
08-02-2010 09:34 PM
DaMole
09-25-2007 02:24 PM
Quick Reply: Wiring diagram for fuel pump circuit ??
