How to request an official Build Sheet
#77
1FT-United States Manufactured, Complete truck
E- GVWR:6,100lbs
F14- F-100 Regular Cab, 4x4?
Y-4.9l I6
F
L
A
48258-Sequence Number
Truck looks to have an Open Differential with 3.08 Gears.
That's my unprofessional crack at the VIN.
E- GVWR:6,100lbs
Y-4.9l I6
F
L
A
#78
N: 1FTEF14Y0FLA48258
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: UNITED STATES
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: E
Brake System: STANDARD
GVWR Class:
Restraint: ACTIVE (MANUAL) BELTS
GVWR Range: 6,001 - 10,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: F14
Vehicle Line: F-150
Vehicle Type: Truck
Engine Type - 8th Position
VIN Code: Y
Engine: 4.9 L
Cylinders: 6
Fuel: Gasoline
Engine Manufacturer: FORD
Model Year - 10th Position
VIN Code: F
Model Year: 1985
Assembly Plant - 11th Position
VIN Code: L
Assembly Plant: MICHIGAN TRUCK, MICHIGAN
Production Sequence Number - 12th - 17th
VIN Code: A48258
Prod Sequence Number A48258
#80
on
here is what ford fleet decode gives me https://www.fleet.ford.com/maintenan...ls/default.asp
VIN Code: 1FT
Make: Ford
Body Style: Pickup
VIN Code: E
GVWR Class:
VIN Code: F14
Vehicle Line: F-150
Vehicle Type: Truck
VIN Code: Y
Engine: 4.9 L
Cylinders: 6
Fuel: Gasoline
VIN Code: F
Model Year: 1985
VIN Code: L
VIN Code: A48258
VIN Code: 1FT
Make: Ford
Body Style: Pickup
VIN Code: E
GVWR Class:
VIN Code: F14
Vehicle Line: F-150
Vehicle Type: Truck
VIN Code: Y
Engine: 4.9 L
Cylinders: 6
Fuel: Gasoline
VIN Code: F
Model Year: 1985
VIN Code: L
VIN Code: A48258
Originally Posted by Ardwrkntrk
Color code '2E' is Light Canyon Red.
I know because mine is too.
WB: 117 = 117" wheelbase
GVWR F141 = 5700 F-150 4x4
Body Code BD4 =
B = Vinyl seat
D = Interior Color Red
4 = Back of Cab Code = Regular Cab styleside pickup
TRANS A = New Process 435 4 speedD = Interior Color Red
AXLE = 18 = 3.08 gear ratio / Capacity 3750
DSO 47 = District Sales Office = Cincinati
#81
Received 5,160 Likes
on
#83
Yep. 31 spline axles also.
1980-1983? trucks had a option of the old 9", if I remember correctly.
And if memory serves me correctly, there was a funky axle something like an 8.25"? I can't remember the size right off hand though.
But yeah, yours' is an 8.8"
#84
Ford Rear axle codes used from 1981-1986
13- Ford 9" 2.75 ratio 1981-83
13- Ford 8.8 4.11 ratio 1985-86
H3- Ford 9" ls 2.75 ratio 1981-82
H3- Ford 8.8 axle 4.11 ratio with limited slip 1985-86 (3800 pound)
14- Ford 9" 3.00 1981-1986
H4- Ford 9" 3.00 Limited slip diff 1981-86
15- Ford 9" 3.25 1981-82 and 2.73 in 1983
H5-Ford 9" 3.25 limited slip 1981-82 and 2.73 in 1983
16- Ford 9" axle 3.50 ratio (3750 pound)verified
H6- Ford 9" axle 3.50 ratio with limited slip (3750 pound)verified
18- Ford axle 8.8 3.08 ratio (3800 pound) 1983-86verified
H8- Ford axle 8.8 3.08 ratio limited slip (3800 pound) 1983-86verified
19- Ford axle 8.8 3.55 ratio (3800 pound) 1983-86verified
H9- Ford axle 8.8 3.55 ratio with limited slip (3800 pound) 1983-86verified
23- Dana 60-3 axle 3.54 ratioverified
24- Dana 60-3 axle 3.73 ratio verified
29- Ford Semi Float Sterling 10.25, 3.55 ratio
B9- Ford semi Float Sterling 10.25, 3.55 ratio limited slip diff
B5-Ford semi Float Sterling 10.25, 4.10 ratio limited slip diff
39- Ford full float Sterling 10.25 3.55 (single rear wheel)
C9- Ford full float Sterling 10.25 3.55 (single rear wheel) with limited slip diff
35- Ford full float Sterling 10.25 4.10 (single rear wheel)
C5- Ford full float Sterling 10.25 4.10 (single rear wheel) with limed slip diff
33- Dana 61-1 3.54 ratioverified
C2- Dana 61-1 3.54 ratio with limited slip diffverified
C7- Dana 60 with a 3.54:1 ratio used in F250 in 1981-83 verified
52- Dana 70-1 HD 4.10 ratio (8700 rating)verified
53- Dana 70-1 HD 3.54 ratio from 1983-86 (4.56 in 1982) (7400 rating)verified
E2- Dana 70-1 Hd 4.10 ratio with limited slip diffverified
49- Ford Sterling 10.25 dual rear wheel 3.55 ratio (7400 rating)verified
D5- Ford Sterling 10.25 dual rear wheel 4.10 with limited slip diff (7400 rating)
69- Ford Ford Sterling 10.25 dual rear wheel 3.55 ratio (8250 rating)
F5- Ford Ford Sterling 10.25 dual rear wheel 4.10 ratio limited slip (8250 rating)
#86
While getting something out from behind the seat of my truck I saw a piece of paper hanging out from the bottom of the back of my drivers seat. It was only half of the build sheet, I fished the other half out that had been cut by the seat frame. I don't know if they are always there but it might be easier to get than one from Ford.
#87
#88
Can anyone help out a complete newbie who needs some information on his truck in order to help diagnose/repair his truck? 1FDKF37LXGPB09751 is the VIN on this machine, and when the "autoVIN decoder" (from this site) looks it up, they only see a Ford Styleside pickup.
1FDKF37LXGPB09751
1FDKF37LXGPB09751
#89
You can decode (look up) both your VIN + Certification Label (and boatloads of other stuff, some in excruciating detail) as provided by the factory documentation, and Gary has spent a fair amount of time making a clickable, easy-to-use version:
VIN Decoding - ???Gary's Garagemahal
Certification Label - ???Gary's Garagemahal
