How many mpg's are u guys getting in 5.4 superduty
Old 07-11-2013, 04:26 PM
BigBlue99's Avatar
BigBlue99
BigBlue99 is offline
Anywhere from 9.5 to 11.5. Seems the wind plays a big role. I have been running 5startunes (93 & 87 performance) and stock still gets better fuel mileage consistantly. This is trended over a minimum of 5 tanks each tune. 93 performance is the worst but not that noticeable with ave. mpg at 10.1 and stock getting ave of 10.8.
  #122
Old 12-10-2013, 09:12 AM
coleaukee's Avatar
coleaukee
coleaukee is offline
<10MPG '05 Crew Cab Long Box
I have been tracking my mileage very accurately, being an Engineering student. It has been right around 0 degrees and all of my driving is in 4x4 and on hills. I try and keep RPMs low. The last two fillups have been between 8.1-8.4.
  #123
Old 12-19-2013, 10:15 PM
wbrook_ford's Avatar
wbrook_ford
wbrook_ford is offline
2003 F250 single cab auto 4x4
Just filled up, 9.8 mpg. Mostly short trips around the farm, more idling this time of year. Snow and 4wd depress mpg as well
  #124
Old 12-28-2013, 04:06 PM
seuadr's Avatar
seuadr
seuadr is offline
2008 F350 5.4L crew cab, long box 4x4. I've been hand calculating my miles (although the dash calculator has been fairly close) stock (original tires from when i purchased it a couple months ago, aired to i have no idea) i went through several tanks at about 60% freeway 13 overall average mpg. i then installed a 5 star tune (87 econ; also brand new E rated tires to 65 PSI - thinking about messing with tire pressure, but don't know if it is worth the hassle) and i've run 3 tanks through it now, i've had an average of 14.4. when it was a little warmer, i was actually at 15.1 but the last tank really brought me down. I think that my 4x4 hubs aren't fully unlocking (just going by road feel). i've got shocks on the way, going to rebuild the hubs at the same time and see if my suspicion was correct.
  #125
Old 01-11-2014, 04:43 PM
Frankenduty00's Avatar
Frankenduty00
Frankenduty00 is offline
2000 F250SDLB 4x, new Jasper 5.4 2v, AMSoil in every box, AFE intake, Magnaflow muffler.
10-11mpg city on winter blend fuel
14 hwy winter blend fuel
add 1-2 mpg in summer. DEQ up here adds to much crap to fuel.
I have just installed a new x pipe in front of cat that made a huge difference in performance now I am checking mileage.
I will look at Transmission slip and a programmer next.
Regards,
MK
  #126
Old 03-19-2014, 02:58 PM
almeras's Avatar
almeras
almeras is offline
2008 F250 Crew Cab Short Box, 5.4, 6-spd manual, 4x4, 140k.
2235 miles in 4 days. 85% highway, 10% city, 5% in 4x4 through a few inches of snow. On the highway, averaged 75-80mph. A couple hundred pounds of me and a couple hundred pounds of gear was the only cargo.
The only add-on that may (arguably) have helped with mileage is a tonneau cover (that failed in the last 200 miles).
Computer varied between 12.3mpg and 13.6mpg during the trip, but said 13.1mpg when I got home. Hand calculated, I got 13.4mpg for the whole trip.
A little better than I was expecting, but still no where near what I got on a very similar trip with my Duramax a few years ago. I think I averaged 21 or 22 mpg empty. But, the upfront savings of buying the gasser will still save me money in the long run, though.
  #127
Old 03-30-2014, 02:01 PM
bussbee's Avatar
bussbee
bussbee is offline
i get around 12miles to gallon my truck is very loaded i am thinking of buying a 2014 250 v8 6.1 litre what do you think
  #128
Old 03-31-2014, 08:39 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
I don't get it, I have a cylinder 4 misfire and a random misfire and im still getting 14-17 on the highway. And a Ticking VCT....
2006 F-250 Ext. Cab. Short Box
5.4 Torqshift
133,000 miles....
  #129
Old 04-05-2014, 01:18 PM
SDTriton250's Avatar
SDTriton250
SDTriton250 is offline
I just bought a new Prius to use for my work route vehicle and the Mrs is driving my F250. My 14~mpg very light city in the F250 went to 11 with her driving her short 6 mile each way commute. The Prius is returning 50-53 mpg per tank averages city and 47~ interstate at 74~mph. This way I get to keep the truck and make some money with mileage reimbursements.
  #130
Old 04-05-2014, 10:25 PM
Aune163rd's Avatar
Aune163rd
I just carpool and pocket most of mine lol.
  #131
Old 04-07-2014, 11:56 AM
TheBlueGoose's Avatar
TheBlueGoose
TheBlueGoose is offline
1999 5.4 V8 Triton SD Crewcab XLT 4x4 152,00 ml. get about 10 city and 18 highway, just had boots and plugs replaced so I haven't had time to check yet
  #132
Old 04-30-2014, 01:49 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
10.3 to 11mpg
87K miles
4X4 CC
  #133
Old 05-03-2014, 10:59 PM
TheBlueGoose
Hey Speakerfritz, the mileage I posted is not exact, in fact it's a guess-tament at best.. I will run it tomorrow and get the actual mileage and post it..
  #134
Old 06-29-2014, 10:37 PM
Gary Staines II's Avatar
Gary Staines II
Gary Staines II is offline
5.4L 2010 Ford Platinum MPG
As a daily in town drive I avg 13.7 mpg and on the Highway about 18.5mpg but I have the family with me when on the highway. Just got finish with a trip to Corpus Christi and I managed about 9.5 mpg coming back and on the way there I only got 8.5. Not to sure of the difference other than the tail wind coming back. My travel trailer is 33.3Ft long and weights about 8500 loaded. I keep it dry till I arrive on site so its about 7800 when towing I think. about 1000lbs of passengers....yaa were a bit heavy too. I was very impressed with the 5.4L easily pulling the load and not once did it over heat and I maintained 65mph the entire trip. I always set the cruise so I can concentrate on the road more. It will get up to 75 and 80 effortlessly but that's just not safe with a trailer. Hope this helps someone who might be wondering about the 5.4L. I have been thinking of a 2014 Platinum Long wheel base 4x4 with the 3.5l Twin turbo since I don't pull often and it would definitely be a better daily drive and supposedly pull with more power but im still satisfied with the 5.4 knowing it has to strength and was actually used for the F250's just a couple years ago.
Last edited by Gary Staines II; 06-29-2014 at 10:43 PM. Reason: added the in city driving
  #135
Old 07-04-2014, 04:41 AM
blwnhemi's Avatar
blwnhemi
blwnhemi is offline
Glad to hear Im not the only one that's horrified by the terrible mileage. I have a 1999 F250 SCab 4x4 super duty w/I think 3.73 gears all stock except for the K&N filter w/only 60,000 mi on it and we get a consistent 12mpg. Its going to be for sale very soon as much as I like the look of the truck, its also gutless compared to our 93 Dodge Cummings E250 4x4
Quick Reply: How many mpg's are u guys getting in 5.4 superduty
