How many mpg's are u guys getting in 5.4 superduty
#76
I have a '03 f350 5.4 4x4 crew cab long bed. 98k miles. All stock except for K&N filter and Predator tuner. The tuner woke this truck up so much that it does not even seem to be the same truck. Much better throttle response. I went on a 180 mile one way trip to buy a utility work top for my truck. On the way there I got 17.6 mpg. With the top on I got 13 on the way back. Definetly need to take the top off for trips! Tuner was worth every penny ($169). I think the truck was getting around 10-11 before i installed it.
#77
Predator Tuner
I just checked my old emails and found it. I messed up on the price.. it was 269.00. I bought it from 4wheelonline.com. I have not customized anything on it. I just used the 87 octane setting and man did it make a difference! I bought this truck from a friend of mine and just figured that the motor was too small for the weight of the truck. When you put the accelerator to the floor it felt like you were taking on in 2nd gear. Now it jumps whne you hit it. Mileage really impressed me. My friend got the same tuner for his 2010 Silverado and he can barely notice a difference. I guess my truck was just not right from the factory.
I have to say I was hoping for more features on the tuner, but I think I got my moneys worth with performance and mileage.
#78
#80
#82
mpg'sss?
Reading these coments makes me wonder, why the big differences? But may be it's a Ford thing. We owned a low mileage ( 45t orig in 99 when we bought it) '83' F-250 XLT 2wd, that was a great truck, the heavier you loaded it the better the mpgs got. Empty maybe 8 or 9, put 50 bales of hay in the bed and get 10 to 10.5, hook on what we affectionatly called the giant red box, a 23 foot draft horse trailer with living area and add two 1000 lb AQHA mares and the milage went to 13.8 to 14.9. Needless to say really miss that truck. Now own a '08' SD 2wd basically same truck but younger and higher milage, and it gets 10 to 11.9 town unloaded, and we just drove it 3000 miles with a truck cap and load of belongings and got up to 16.9 mpgs.
#83
L Parker, you can't REALLY believe that can you? I mean come on, 8-9 empty and almost 15 towing? I think some people don't realize what a difference in mileage you will see{incorrectly} when you check mileage by where the gauge needle is, or by fueling up after a short trip. The only correct way to know for sure is to fill the tank, then use almost the whole tank and refill it to FULL the same way each time. If you try to drive 20 miles and refill you can get a variance of as much as a a gallon or so of how much fuel it takes, depending on how it is filled, where, how level, temp. outside.... A gallon in 20 miles is a big mileage changer versus a gallon in a 29 gallon fill, and 400 miles. Not trying to be rude , just sayin...
#85
#88
Hey guys I'm from the dent-side side of things. I'm looking into stepping up and getting a newer truck. The one I'm looking at is a 02 F250 crew cab long bed with the 5.4 and an auto and 4x4 with 70k on the drivetrain. What kind of mileage can I expect? From what I've read I'm looking about 10-12 for an averag. Any insight in this new creature would be great.
#90
