buzzing or howling after key is turned on after glow light goes off???
OK weird thing happening on my 2003 F 250
Once I turn the key on it does the normal buzzing for plugs and after my light goes out to go ahead and start the buzzing/howling sound continues for a while.
Also sometimes while the truck is running you can hear the howling sound in the cab but no codes or nothing
Any input on what could be causing this to happen?
Not sure if power steering pump or something or something else causing this to happen.
It's almost like a buzzing slash howling sick sound but it goes away if you wait long enough
Thanks
Thanks
The howl is only with the engine running and is definitely not the fuel pump, which is in the back.
The howl comes from the front, is low frequency, and could be a resonance from the air intake system.
In your case, the buzz from pass is probably the vacuum pump, electric, which I do not have.
Check the little air pump on your passenger fender well under the hood. I had the exact same noise and it was the air pump running constantly due to a vacuum leak at the solenoid on the fender. The tech at the local dealer changed out the solenoid for one he had laying around the shop and saved me 90 bucks. You just need the key turned on and have the hood opened to find the culprit. Once I did that it was easy to find.
Andy's Beast
25
03-03-2020 01:44 PM
John Main
03-23-2017 08:15 PM
goodolboy1080
08-09-2016 06:42 PM
goodolboy1080
1997-2006 Expedition & Navigator
06-01-2016 12:00 PM
cferguson77
03-28-2016 02:29 PM
