1992 302 knock sensor
Old 01-08-2011, 01:57 AM
carter2011's Avatar
carter2011
carter2011 is offline
Hey. I am new to the forum and my truck is a 1992 F150 5.0/302 4X4 swb. I recently bought the truck and in process of complete restore have found out that the manufacture has discontinued the knock sensor and I have had no luck at local parts shops. Truck runs great but stil would like to find a replacement for it. If anyone has an idea please HELP!
Old 01-08-2011, 08:44 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
I have the same problem...Mine is DESTROYED!!!!!..Once again...DESTROYED!!!! It amazes me how the P.O.'s drive these vehicles in the GROUND!! Just continue to dump oil in it and some gas, maybe put some air in the tires(Only 'cuz they LOOK low) drive it further in to the GROUND...AND AT THE SAME TIME, GET IT INSPECTED!!!!!!!!
I did see some available thru E-Bay. You can do a search here, hence someone was just asking for one for a '92 4.9L and could not find one anywhere.
Old 01-08-2011, 10:51 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,173 Likes on 927 Posts
This thread from another forum has some great info: FullSize Bronco.com - Knock Sensor
Old 01-09-2011, 08:32 AM
timbersteel
Thanks rla2005! I've been looking for that.
Old 01-09-2011, 11:54 AM
Kapusta's Avatar
Kapusta
Kapusta is offline
Received 1,715 Likes on 642 Posts
Looks like I'll be saving the KS from my old 5.0L. That's an expensive little part.
Old 01-09-2011, 02:08 PM
lew52's Avatar
lew52
lew52 is offline
...I wound also keep the roller cam & lifters , dog bones , and the spiders from the 94 , and the distibuter , guys on here will buy them from you , its a good upgrade from the older 302s....Lew
Old 01-09-2011, 02:34 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
I plan on keeping the distributor from the old 302 as well since it's almost new. I am planning on selling just about everything else from the old 302 to try to recoup some of my losses.
Old 01-15-2011, 05:44 PM
kingfoot's Avatar
kingfoot
kingfoot is offline
can anyone tel me wer its located the nok sensor that is
Old 01-15-2011, 06:45 PM
timbersteel
Should be located on the back of the block, below intake manifold, close to the bellhousing.
Old 01-15-2011, 06:46 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
At the back of the block on top behind the intake manifold. At least I think that was it.
Old 01-17-2011, 05:03 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Here's a picture of where it is:
Old 01-25-2011, 01:38 PM
kingfoot's Avatar
kingfoot
kingfoot is offline
mine is spark knocking very bad unles i use 93 octane if i un plug it will it help
Old 01-25-2011, 01:52 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
^ unplugging a KS will not help. It might even cause a fault code and the CEL light to turn on. You need a new one.
Old 01-25-2011, 02:38 PM
73FOMO's Avatar
73FOMO
73FOMO is offline
If sensor detects knock...retards timing 4 degrees. If you are not expierencing knock you could run it without....may or may not set check engine light. I believe the trucks were the only 5.0's to even get the sensor. I am guessing due to possible pulling of heavy loads with today's great fuels.
Old 01-25-2011, 02:53 PM
kingfoot's Avatar
kingfoot
kingfoot is offline
yea wer u find that
Quick Reply: 1992 302 knock sensor
