My heater is 6 volt so i bought a reducer to put before the switch. The switch is a pull switch with two positions, And on the switch the terminals are labeled B and M. Is B battery or blower and what does M stand For? Heater has one wire?
If you ever decide to go to 12 volt the motors and switches are really cheap. I think you would be happier with this set up because of increased blower speed, but a reducer will work fine also
Okay thanks, I would like a 12 volt but thats on the back burner for now. Think i have to pop for the 12 volt wiper motor with the extra cash. I put 6 volts to it and i just get a spark no movement. I ground black and put the hot to red or green.
i'm not sure, but i dont think the 6v wiper motors have a separate ground wire. that would explain the sparks. I'd have to dig out the diagram and look again, but i do believe the 4 wires/connections are low, high, and park and the shut off sensor kinda jobbie. i'll dig out my service manual iffin you want me to
no matter what else, it's nice to see the diagrams survive and still be of service. I can dig up the wire colors tomorrow iffin you still want. which does what. and you're right, 3 wires from the motor, 4 at the switch with power. just aint been out to the icebox called the garage in a few days. (11 below by morning i hear tell).
Kitchen thermometer says 5 below at the moment, and it reads warm as it's sensor is mounted to the exterior wall. I still kick myself HARD for not running a gas line out to the garage when i had the trench and walls open to do the new electric out there. running the 220v heater out there makes the electric meeter spin like a frizbee on these kinda days.
Found the switch with the cut wires in the box of crap the PO gave me. F=Green A=Red P= black B=batt According to the stampings On my switch out of a 53 P is where B is and B is where P is on JD's Drawing. Anyway my motor is still dead, So i guess it's the $145.00 replacement 12 volt
