Spin-on trans filter
I just added the Diesel Site external spin on filter.
https://www.ford-trucks.com/forums/1...ny-filter.html
It is plumbed the way that you describe. I didn't have anywhere inside the frame to mount it.
I installed my spin on filter on the inside of the frame rail, between the radiator and the engine cross member. There is room there to install if you choose. I ended up buying all the parts and fabricating my own bracket for the mount. It works out really well in that location as the cooler lines are right there.
I did mount a pressure gauge on the inlet side of the filter along with another transmission temp sender. This way I can see the post cooler temp, and the pressure gauge will show if the filter is bypassing or not. I eventually want to install two pressure senders and route them to an electric gauge in the dash, where I can monitor the pressure of pre and post filter from the dash.
Here is the write-up I did on it.
Spin-on Transmission Filter Write-Up
It is easiest to do it post cooler as the lines are simple spring clamp connections. The pressure is also less post cooler than pre-cooler.
The advantage of doing it pre-cooler is the cooler should never get any debris in it from failed parts in the transmission as it would be filtered before the cooler.
One dis-advantage to doing it pre-cooler it the possibility of increasing the pressure at the transmission cooler by-pass valve and causing a short circuit of the cooling system. IIRC the bypass tube is set at something like 45 psi?. For some reason that number sticks in my head, but not 100% on that.
Search for Gates 27065 that is a P/N for 3' sections. 25' sections are P/N 27066
Online it is available here, 1/2" Transmission Cooler Hose
Or do you just mean the tranny filter? I also have an engine oil by-pass filter installed on mine, but it is behind the transfer case on the left inside frame rail.
