Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-02-2011, 03:44 PM
threefiftyone's Avatar
threefiftyone threefiftyone is offline
1996 Ford F-350
threefiftyone is starting off with a positive reputation.
460 intake
I'm trying to figure out if i can put a big round air filter in place of the factory air box on my 460 EFI.
Are there going to be issues with the MAF? I was searching through the 460 Ford Forum website and they say that you cant just put a different filter assembly in place of the old one. There are too many issues, things i've never heard of.
What are your opinions on this?
I bought a K&N clamp-on filter with a 4" inlet.
'96 F350 4x4 auto
__________________
Don't ya just hate those a_$_$_h_o_l_e_s who post just to increase their numbers but actually have nothing meaningful or relevant to say? I DO. So unless you're going to make a difference, just don't even bother. Everyone else will see that too. Have a good day
  #2 (permalink)
Old 02-25-2011, 07:48 PM
92f2504x46.9's Avatar
92f2504x46.9 92f2504x46.9 is offline
1992 Ford F-250
92f2504x46.9 is starting off with a positive reputation.
was wondering what to do with my 460 as well , i just cut out some plastic pieces today from the factory breather setup , need to find or make a two into one setup ?
__________________
92 f250 4x4 extra cab 460/E4OD/BW1356
05 GT convertable pony
  #3 (permalink)
Old 03-01-2011, 05:35 PM
Beechkid Beechkid is online now
Garage is empty, add now
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
If you do an online search for “air filter test” there is a lot of very good information.
If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! The OE’s have an excellent air intake system.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #4 (permalink)
Old 04-21-2011, 03:10 PM
RPelkey's Avatar
RPelkey RPelkey is offline
PREMIUM SPONSOR
RPelkey is starting off with a positive reputation.
K&N offers intake system 57-2510-1 which will give you an 11hp increase. This system will require you to remove the factory air box. Unfortunaltey this is a stage on system so you will still utilze the factor duct work from the throttle body.
You will not have any issues with the maf sensor with this kit it is a direct bolt in kit whic utilizes your factory sensor.
__________________
Product Specialist
K&N Engineering Inc. - www.knfilters.com
1455 Citrus St., Riverside, CA 92507
800.858.3333
  #5 (permalink)
Old 04-21-2011, 05:27 PM
When you take into account the standard 5% dyno deviation......that means basically you have not changed any hp or tq.
__________________
  #6 (permalink)
Old 05-25-2011, 12:54 AM
mr7confused's Avatar
mr7confused mr7confused is offline
mr7confused is starting off with a positive reputation.
Jordan McFarren
Quote:
'96 F350 4x4 auto
Do you remember any of these issues?
  #7 (permalink)
Old 05-25-2011, 09:14 AM
RPelkey's Avatar
PREMIUM SPONSOR
If you visit our website at knfilters.com you can view the installation instructions for this kit. This is a direct replacement kit simple install
  #8 (permalink)
Old 05-25-2011, 12:16 PM
and read all the tech bulletins from ford, GM & Dodge about the contamination issues and warranty denials. I personally experienced this on a brand new 1997 Cougar sport (V8)- which I still own today. I have all the oasis reports documenting the contamination issue. After 3 replacements, on the 3rd one Ford requested the brand new K&N filter on the beand new car be removed, which I did in front of the service adviser. There have been no oil contamination or even a sensor failure to date after the K&N removal.
K&N despite being provided copies of the docs, denied responsibility and even refused to buy back the filter (which I bought directly from them).
__________________
  #9 (permalink)
Old 05-26-2011, 03:06 PM
spongebob's Avatar
spongebob spongebob is offline
spongebob is starting off with a positive reputation.
Beechkid;
I've heard this story before. Didn't you also approach K&N reps at the drag races, clutching your prized Oasis reports in your fist, waving the reports in their faces, saying "SEEEE???? I TOLD YOU SO!!!"??
You seem to be vastly misinformed. The TSB's which you cite do discuss contamination; however they discuss the MANY sources of contamination, which are already present in a vehicle regardless of the type of filter used. Ford has a TSB (Article No. 88-23-10, ironically, which includes your 97 Cougar) that you should probably read. It begins:
"MAF sensors can get contaminated from a variety
of sources: dirt, oil, silicon, spider webs, potting
compound from the sensor itself, etc."
The GM bulletin (04-07-30-013B) says:
"The use of an aftermarket reusable air filter DOES NOT void the vehicle's warranty."
Not to mention all the testing, research, etc. K&N has done to defend their name and protect their customers. Don't know why they singled you out...their customer service is like Nordstroms...they'll take ANYTHING back. All you have to do is look at their website under "warranty". Guess they may have been ticked off after the waving-papers-in-faces episode...
  #10 (permalink)
Old 05-26-2011, 04:16 PM
Quote:
Originally Posted by spongebob View Post
Beechkid;
Everything you say is true (and if you carefully read all of my posts regarding this, you will see that I even state what you have stated) except......
1. I never yelled at any K&N rep
2. I never waved any oasis report directly in the face of a K&N rep stating "I was right" (because in 1997, Ford was not using OASIS, that was a Hughes Space & Comm specific satellite system that a portion of which was used by GM, who owned Hughes at the time).
3. I did present copies (while holding my originals) service docs to K&N staff
4. K&N just ignored the documentation & was specifically to the K&N filter....despite absolute proof by both the dealer & Ford that the oil from the filter contaminated the air intake sensor (twice in 30 days) , they still inquired if I had re-oiled the filter....the repeated answer, no- it was installed straight out of the box. Ordered straight from K&N.
If you go to flatratetech and look at the training vids that are made specifially for ford, they specifically id oil coated air filters as an issue to watch out for to deny warranty claim repairs. GM has a similar vid....and it is true that the mere instal of an aftermarket filter does not void a warranty, they teach specifically how to determine if the oiled air filter caused a failure and that does deny warranty claims.
This TSB did not exist in 1997. In addition to all of this...
1. Despite having a filter that will flow up to 900 cfm (which the K&N will flow - approx), it makes absolutely no performance difference for a stock engine such as the 5.4 in the trucks which can only suck in a max of 480 cfm...the oem filter will flow up to 500 cfm
2. despite claims of "cold air", numerous persons have installed temp sensors in both the oem & aftermarket CAI's.....there is no temp change
3. Filtering quality, great for off road, questionable for street in terms of air flow versus particulant pass-through as compared to the competition (such as WIX)
4. post filtering flow...K&N is poor by comparison to other performance filters such as WIX...testing has been posted numerous times on the web-site, and consistantly demonstrates many filters have a better post filter flow characteristics when compared to K&N, which created circles or flow reversion.
Despite a great marketing program (which I do give credit to K&N, Summit, etc) for, basic scientific tests, that have been repeated, show the same results.
and last but not least.....I still have all of my oem docs identifying mileage, dates, etc of intake sensor failure and when it suddenly stopped- with the removal of the K&N filter.
now, do I use K&N specific filters in other vehicles...YES....Including my 1965 300 hp mustang (it is predominently a show vehicle and the paper elements cost me $30 each to replace)...but it has a Holley carb; would I use or recommend any oil-air filter on any MAF equipped vehicle- ABSOLUTELY NOT!
Given the response I had in 1997/8 from K&N, would I buy another K&N product- ABSOLUTELY NOT!
__________________
  #11 (permalink)
Old 05-27-2011, 10:52 AM
spongebob's Avatar
whew...THAT was a mouthful...
  #12 (permalink)
Old 07-06-2011, 09:40 AM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
Don't over oil the filter and it wont give you any trouble.
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
  #13 (permalink)
Old 07-06-2011, 07:37 PM
Quote:
While that certainly would help, on my new 1997 Cougar Sport (V8), I installed a new, out of the box, stright from K&N replacement filter. It contaminated/damaged air intake sensors- twice in 60 days...documented by Ford engineers & Dealer...they put it in writing on the OASIS report. I pulled the filter in front of the tech & service writer with the install of the 3rd intake sensor....still own the car, not a single failure. K&N would not honor their warranty either stating "They must be wrong".
__________________
  #14 (permalink)
Old 07-07-2011, 10:09 AM
spongebob's Avatar
is there an echo in here?
  #15 (permalink)
Old 08-02-2011, 08:37 AM
400inatruck's Avatar
400inatruck 400inatruck is offline
400inatruck is new and has a neutral reputation at this point.
Well I just found a fault in your writing, don't know if you meant to or not, but you said once before "twice in 30 days" then you said "twice in 60 days". Make up your mind.
Tags
1997, 460, 92, air, cool, duct, efi, f250, filter, ford, intake, intakes, kn, remove, system, systems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
