No choke needed on Propane Conversion
Old 10-03-2010, 09:41 PM
1978Crew's Avatar
1978Crew
1978Crew is offline
Am I remebering correctly?
No choke is needed on a dedicated propane fueled engine. Since the fuel arrives in the mixer as a gas, the atmospheric pressure equalize the mix on cold mornings, so no choke is needed.
I am planning the conversion but am currently hobbling along with the gas carb and do not want to mess with a new choke if I will not need it for propane.
Old 10-04-2010, 02:53 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
Technically yes. Propane systems do not have a choke but most of them have a "primer" system to make up for leak down pressure losses and low cranking vacumn on cold starts.
Most systems will lose the fuel charge between the outlet of the vaporiser and the inlet of the mixer overnight so without a primer you would have a long crank when its cold, and on bigger engines in hd trucks the cranking vacumn is low so that somtimes they do not create enough to open the vaporiser so a primer gives you a "shot" of fuel to overcome this.
Hope this helps
nobearsyet
18
03-21-2021 09:03 PM
PaulsEdge
Alternative Fuels, Hybrids & Mileage
01-09-2017 07:09 AM
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-06-2014 11:27 PM
cchandler4704
1997 - 2003 F150
10-01-2012 07:29 PM
1978Crew
13
10-17-2010 07:30 AM
Quick Reply: No choke needed on Propane Conversion
