9" ford and dana 44 brake interchange ability
Hey guys I remember someone saying that the pre 72 9" ford rear brake components and drums could interchange with the stock dana 44's. The drums on the 44 are narrower right? Would replacing the drums and pads on the 9" with a dana 44 drums and pads make the axle more narrow to maybe fit a bigger wheel and tire?
No. That part doesn't change. The width of the axle comes from the housing, and especially the shafts. The brakes just fit around the shaft. If you're going to be swapping brakes, you need to do it as a complete set of matching parts; drums, shoes, hardware, and backing plates.
Rear brakes were the same width thru 1967.
