sh__ keeps tearing up
(56 F250 w/ 6 cyl (223). In the past 3 weeks I've had to replace the coil, points, fuel pump, water pump, and have radiator rodded out (30% blockage).
Now I have no compression on the #1 cylinder, and water in my oil. What do you think?..cracked head?.....I'm about ready to pull it out and throw it over in the holler. Maybe upgrade to 302.
On the bright side, theres lots of folks out there that will practically give away a straight 6. Lots of folks pull the 6's out to install V8's. Keep your eyes open on the classfieds here, on Craiglsist, over at the HAMB, etc and you might find one pretty cheap.
Its worth pulling the head to see if its a head gasket. Nothing says its the holidays like having everything break all at once......
Bobby
Bobby
Bobby
Bobby
Check out what Col. Flashman's done with such a humble "work-horse".I like it,and would be proud to put that in the "old" truck(48-52) I hope to someday have.
1958 Mercury M100 4x4 - '58 223c.i. I-6
I was just looking thru this thread and spotted a Spectre fuel pressure regulator on your truck! Get rid of that POS ASAP!! It may not be "the" problem, but especially if you have it turned down to 1.5 - 2.0 psi, it will do all kinds of bad stuff. They are bad ju-ju. Get a Holley 12-804 at AutoZone. The Spectre regulators are my personal crusade, I fought one for a year, til I threw a gauge on the line downstream of it and saw it see-saw between 0 and 5 psi at idle. At higher flows it would apparently lock open or lock closed, depending on its mood. If nothing else, check for a filter screen on the inlet, up inside.
