Electric Vs Manual fuel pump?
Im rockin the electric fuelpump...
dunno anything about it starting better, truck allways started right up...
but before I did the conversion, it had an electric pump feeding the mechanical fuel pump. but the eletric pump was shot and doin nothing but clocking my fuel filter with chunks...
Just go electric and remove that extra drag on the engine...
I've run both...I prefer mechanical pumps for simplicity and because I can't stand the whine of electric pumps...and sometimes you have to worry about regulators. It's also been my experience that when an electric pump dies...you're dead in the water, while a mechanical may leak...but can at least get you to a parking lot or something. At this time, my main pump is of the emchanical variety on all my rigs, but, I do have an electric pump with spare hose, wires, etc. in my glove box because I have experienced flatting spotting and other issues on fuel eccentrics before, relegating me to only electric pump use.
About the only benefit I could see to an electric pump on an otherwise stock vehicle is that it would allow you to re-fill the float bowl on the carb without cranking provided you let it sit so long that all the fuel had evaporated. The mechanical pump has worked fine for 30+ years, why add more load to your electrical system for no reason?
nonrev321
13
07-30-2015 11:30 PM
nonrev321
07-24-2015 10:12 AM
97redbeastford
General Automotive Discussion
02-11-2014 11:48 PM
r_reed
09-22-2011 05:58 PM
