need some help with steering collum
I'm not familiar with Helix. Flaming river makes some good stuff, but I've had positive personal experiences with ididit products, and if I was making a choice, I'd likely go with ididit again. For you being in Europe, ease and cost of shipping would probably play a large factor in the decission, too.
I'm using an ididit straight column (steel) ...no column shifter...with 4 1/2" billet column drop and swivel floor mount. Quality is good but the billet scratches easy. Also important is the linkage. I used borgeson joints with slip shaft for extra safety.
Be careful with the column. It is top heavy and seems to find the floor easily. I ruined one because of that reason (it was leaning against the wall and fell over destroying the top of the column). Regards.
I use a stock column and three speed column linkage hooked up to modern rack and trans in my Mercury truck, and a piece of polished aluminized exhaust pipe with a bearing at the top and bottom in my last one. A cool old trick is using a piece of polished stainless or chrome exhaust pipe with a piston rod column drop and make your own. I wish I could help on the aftermarket ones, but I have never used one so I can't endorse any. Try and make one and you can tell people "youdidit".
