Tuner / Tire Help (Size correction)
Hey all, I thought before I worked out all the math I'd ask on here. I have a lot going on so it will be a while before I can sit down and mess with this.
I went from a 265/75/16 to a 315/75/16.
The truck has a 3.73 gear.
I can correct the tire size with my x4 tuner, but it has to be done in Revs/mile.
Has anyone else already done this for those sizes or am I going to have to suck it up and do it myself.
A lot of tuners don't adjust for tire size, SCT being one of them. Supposibly they don't want to change anything with the ABS system. Though a small number have been known to be able to be adjusted with the SCT, it may only be a certain strategy codes. The dealer told my dad they can adjust up to 35's when he had his 03' reflashed. My 04' is actually more accurate than factory with 33's than the stock tires that came on the truck.
There is a 3% variance for the speedometer right from the factory. It is hard to be gps matched all the way across the speed range. As you speed up the gap will get worse since you are working with a percentage. 3% at 100mph could be 97 or 103, so at 40mph speedo would read 39 or 41 which you would most likely never even notice.
So getting within a few percent you should be able to call it good. But 5 to 10 mph variance at highway speed is a bit much. Hope that SCT can get you squared away.
