2011 Ford F-350 brake wire
ARE makes truck caps with third brake lights, send them an email for instructions. I gave mine away with the truck when I sold it last month otherwise I would add it here.
If you don't have a third brake light feed to use you may need to add a relay.
I realize that this item below is not what you need, but there are similar items to accomplish your goal.
I am using this relay to "not" have my brake light activate directionals I am adding to the side of my 5th wheel.
2" Heavy Duty Relay Style 2 to 3 Tail Light Converter
2" Heavy Duty Relay Style 2 to 3 Tail Light Converter - eBay (item 180440046079 end time Dec-26-10 10:05:44 PST)
Earlier model trucks had a single blunt cut wire that came out of the main loom towards the rear. It was taped to the loom and had a bit of heat shrink on the end. It was usually labeled "CHMSL" or something similar. It was put there purposely for aftermarket third brake lights.
I'd be surprised if the newer trucks didn't have the same thing.
FuzzFace2
12-24-2016 06:25 PM
Parker05
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-27-2015 09:13 PM
79Supercab
02-22-2015 10:16 PM
JayzDaddy
26
06-03-2013 11:38 PM
