Electrical issue NEED HELP
200 F350 Crew Cab 7.3, if the truck is parked nose down and it rains heavy or snows I get bad problems. One being the heater fan will run without the key turned on. The other is I will loose my speedometer and the over drive light will flash. Once things dry up (?) everything is fine. This has happened to me twice now, this only happens when the truck is parked with a slight down hill position. Any ideals? I do leave the settings in a defrost, high heat, high fan position so the truck can defrost and be warm when I am ready to leave.
Check to see if the windshield has a leak that allows water to collect around the central junction box and other electrical control modules.
Look under and behind the dash in the area above the steering column. If it is wet there, you probably found the problem.
Lou Braun
Lou Braun
I went through and pumped silicone under the seal around the windshield, no problems ever since.
