How reliable is the V10?
I've heard that same argument that they are one thirsty beast, but when compared to my 4.7L Ram, I've only lost a couple of MPGs empty and actually do better when towing the trailer. It's been far more reliable than my Ram and cheaper to get parts for.
I feel that I should add that I bought my Ram new in '03 and by '09 and 130,000 miles the engine was losing power, the rear u-joint was failing again, the ball joints were getting sloppy again, and the upholstery was shot.
Thanks for the help with a Ford V10 engine . Looking for a big van with V10. BTW , whatever you do, DO NOT buy a Ford Diesel. Made by the old International Harvester Co with a new name. I learned the hard way at a loss of over $10,000. No , some Ford diesels are NOT better than others---ALL bad unless you get very lucky. See suits over this engine by dealers, etc. Do your homework before and you will avoid. I am a Ford guy.
But the new 6.7 is a nice engine. And it is not made by IH.
V10 is awesome
I have 267000 flawless km on my 2006 F250 V10.
I have yet to have an issue with my truck. It is the most reliable vehicle that I have ever owned. The only problem that I've had is leaky valve stems haha. It's towed everything I've thrown at it. Only complaint is the small gas tank. 100 litres is too small for a thirsty truck. It would of been nicer with a larger tank.
#28
You are right about the gas tank size. But to be honest, the 29 gallon on my short tank is good for at least 250 miles on the highway. That is longer than I can drive without getting out to stretch!
Interstate driving that is not a problem. If you do a lot of back road driving I would consider keeping 10 gallons or so in the bed. I would change to the bigger transflow tank but the cost is not worth it to me.
#29
1999
17 years
195000 miles
250 cc LB 4x4
changes plugs 3 times
got 60k out of the last set of BFG KO, trying yokohama geolanders now, liking them
replaced the alternator some time back
replace the radiator recently (change coolant 4 times)
replaced both front hubs some 10 years ago(carry a spare in the truck)
replaced some of the coils
brakes and rotors several times
replaced the injectors (didn't really need to, tracing a problem)
replaced the injector plugs(see above)
3-4 battery's
my cd player quit last year
I fixed the overhead console(temp mileage, etc) via ebay for $25
pretty much it..
17 years
195000 miles
250 cc LB 4x4
3-4 battery's
pretty much it..
#30
