1976 MOTOR TRANS SWAP
Hey Gang,
This is a barn find my son and I are building. The vincode said it was a 1975 with a 6 cly and a "G" code transmission. It came with a 300 6 cly attached to a C6 (not installed) We put the engine and tranny and had to change the rear tranny mount (two bolts going into the cross member) to the one to match the cross member on the truck (one bolt through the cross member). The cross member holes will not line up with the chassi holes, and the front portion of the two piece drive shaft will have to be shortend.
My questions:
Should I just drill holes in the chassi to match the new location of the cross member, or find a cross member to match the tranny?
Is there a shorter front portion of the drive shaft available, perhaps the same year as the motor and tranny or just get the drive shaft cut?
Thanks
Planning to do a build tread!
My questions:
Thanks
