1950 F-8 Dump
1950 F-8 Dump
I'm new to the forum, just bought a '50 F-8 yesterday, drove it a whopping 1/10 of a mile so far.
337 flathead, everything seems stock except the later dump bed. If and when I get it reliable enough I may throw a 5th wheel on and look for a similar vintage trailer, but for now its just a cool toy
I'm new to big trucks, can anyone recommend a wheel that will fit this 8 bolt pattern thats not a split rim? Thanks
Cool truck! I have a 1950 F-8 air brake tractor, as well as a 1950 F-7 Coleman 4X4 (https://www.ford-trucks.com/forums/9...7-coleman.html).
You are fortunate that you don't have "split rims", but the lock ring style that you do have are not 100% safe either. Finding tubeless wheels that only fit 1956-62 F-750 and F-800's as optional equipment will be very difficult. It took me many years to find my 2 sets. You will probably have to have a set made.
You must be leaking air somewhere. The air horn valve could be stuck open, but you should be able to hear the leak.
Chuck
Chuck
Compressor was turning, brakes did not seem to work (you can hear the air release when you take your foot off the brake, I didnt hear anything last night, I didnt dare try to drive it) Pressure gauge was at like 10psi or less. I couldnt tell if air was escaping the compressor because it was night and I dont know what the normal sounds of the are truck yet. I'll give it a good inspection on sunday during the daylight. Just wondering if this is a commom problem with a commom fix. Thanks
with any thing that is old you will have repairs to do , and with air brakes any thing that is rubber will rot over the years and most likely when you used it for a short time some thing just ruptured ! could be the brake canisters the diaphragm in them went out , could have rust holes in your air tank , lines could be shot !
no air
Ill bet the unloader valves (2) are stuck. If the compressor is the original
style the unloaders are external and need to be sprayed now and then.
Next I would take the air output line of the compressor and see if is pumping. If not the unloaders have to be up (pry with screwdriver) if up
then to to the governor (round thing on left side of firewall) should be a
bendex type O1. Take cover off and move the valve up and down. Up
means no pumping-Its satisfied, Unloader valves will be down. Valve down
Unloaders will be up pumping. Then the next step will be to charge the
system with shop air. Also to note on these trucks the service brake linkage and or valve gets stickey and you gotta pick up the pedal. If this
is sticky just a little (foot valve) it will bypass and exahaust at the bottom
of the valve. I have one truck that does this all the time, and if a driver
does not lift the brake pedal up >all the airs gone. Just another thing for
the old man to fix. Sam
You got it busguy
Not a coincidence Its the nature of this style with external (rocker arm)
unloaders which should have about .010 clearance. Also I forgot to mention, on the compressor see if it has a dipstick like a lawnmower to
check its oil. It takes regular engine oil. There are about 3 styles they
used like> air cooled self oil lube-water cooled self lubed water or air
cooled engine oil pressure fed. I got no clue what you have, no doubt
it may have been replaced after all the years of service. Myself I
positively despise or hate hydraulic brakes. I trust you still have the
worthless hand brake. Put spring emergencys cans on there and you
will have that extra supply air line for a trailer if you are going 5th wheel.
Napa is just about giving them away. Use 30-30"s good luck sam
#1. Is this how the "VIN" plate is supposed to be mounted ( in the photo below)... in the glove box door with screws? I was expecting those fancy VIN rivets...
By the way, the Engine number begins with 98EQH. anyone care to decode it?
#2. All the documentation I've found says that the GVR of 1948-1950 Ford F8's is about 21,500 lbs single and 37,000 combination. The tag on mine says 32000 lb and I dont know if thats single or combo. I was told by the previous owner that my truck was made from the factory as a dump truck, he said they riveted an extra heavy steel plate on the chassis of only the dump trucks. Thats why I dont know if this one could possibly be 32000 max. single.
For 1950, Ford increased the maximum GVW on all F-8's from 21,500 to 22,000 lbs. Normally, I would have ended my comment there, but your rating plate is very unusual. I have never seen one with a blank area where the GVW could be stamped in. The picture is very blurry, but I assume you are sure that 32,000 is stamped in? If that's the case, then I'm sure the body company (it wasn't Ford) that installed the dump body, and riveted on the fish plates must have done it. They installed the truss under the rear axle as well. Whatever they did, unless they added a tag axle under it, there is no way they legally increased the GVW by 10,000 lbs!
Chuck
Chuck
