Iac Problem?
Iac Problem?
Hello... My 92 f150 302 has some serious idle problems!!
No problem starting the truck ever but when the auto choke
shuts off ..thats the end of it no idle what so ever.
I removed the IAC and cleaned it..no change.
Someone suggested I remove the wire harness and check for changes, nothing happened!
Does that mean it is shot????
Iac Problem?
An EFI doesn't have an actual choke - it just pulses the injectors longer and holds the IAC wider open. Have you pulled the codes?
