351 windsor advice
351 windsor advice
Hi everyone, new to the site. Im Bryn, i live in Los Angeles, CA and have A 1995 f-250 5.8EFI 2WD regular cab, i believe it is long bed and has 2 tanks on a switch. Id like to ask some questions about it. I am proficient with the mechanics of domestic vehicles and can do almost any of the work myself. purchasing automotive specific tools is not a problem either. id like some personal opinions on combos and certain bottlenecks of the motor. especially regarding labor oriented modifications (porting, port matching, welding H-pipe or dual cats). This motor may eventually find its way into a 1982 ford mustang LX 5.0 5Spd i will soon have also.
I would love to know about taking parts from junkyard cars and rebuilding or upgrading internals to swap to the 351, like taking GT-40 parts from explorers and such. Also wondering about the headers and intake manifold, i know they are a big bottleneck for all of the EFI windsors.would love lots of information on the entire induction and exhaust system please. the dual throttle bodies look to flow enough air for an engine of this displacement in mild tune.
The truck was given to me by my employer, Theis Industries. my boss tells me it had a "Target Motor" install at about 190,000 miles. it currently has 221,000. i am wondering exactly what the differences are, if any, between the original motor and this "target motor". he claims also that the transmission came with the target motor. it runs strong and the mileage is not abnormal, no strange behavior, no service lights on dash, and the transmission shifts well and pulls strong. i believe it is equipped with a ford 10-inch axle. the transmission is an E4OD i do believe, but have not checked. As far as i can tell the motor is completely factory. it is equipped with a Flowmaster setup past the cat. Im assuming that the dual exhaust from motor to cat is factory.
First, i'd like to know if there are any junkyard available (rebuild or upgrade of internals is not a problem, vales springs bearings etc) upgrades, this is abigtime as labor is no problem for me the time is there but the money is not as plentiful. but new internals are not a problem for certain things. if anyone has used performance parts for sale compatible with this motor please let me know. would love to hear of experiences with modifying this motor. Thanks very much in advance!!
on
This motor is has pretty well matched induction components on it, the intake, cam, and heads are all sized apropriately for one another, the problem is they're all too small for 5.8 liters of displacement. Look for some GT40 heads off an Explorer, get the cam from a 5.0HO Mustang, and also try to find a GT40 lower for the intake and match it with an Explorer upper(can't use the 5.0 lower as the 5.8 engine is wider). Add 1.7 rockers and a complete exhaust system including headers and aftermarket cats and you'll see significant power increases as long as the EFI and fuel system can keep up. And that is the next issue, to take full advantage of these mods the truck will need mass air, if it doesn't have that now it can be added with some wiring from a donor truck and a MAF computer and meter from either a truck or Mustang.
Thank you! more specifics would be appreciated.
these motors are equipped with the same 19lb/hr injectors as the 5.0, correct?
24 or 30 lb/hr would seem more proper for 351cid.
The explorer donor cars include all 1995-2001 explorer 4 doors, and up to 2005 sport trac models, and 1997-2001 mercury mountaineers, correct?
87-XL-Squared
03-19-2017 04:12 PM
SHELBYGT00
04-03-2016 07:09 PM
compman
03-03-2014 05:19 PM
abninf87
09-21-2009 10:17 PM
abninf87
09-20-2009 08:36 PM
