1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2005 F350 Radio Problem
Old 11-05-2010, 08:52 PM
vitaminj75mg's Avatar
vitaminj75mg
vitaminj75mg is offline
I have a 2005 F350 Lariat dually with 55k miles. Today, for no apparent reason, the radio stopped transmitting sound to the speakers. I had all radio function, but there was no noise. The windows, cruise control and all other elements work fine. I have had no other problems. Is this a fuse, relay or what? I tested what I thought to be the fuse, and it seemed fine. Only thing is I hadn't driven it in a while, but the radio worked when I first got in. The problem occurred after I had driven ~20 miles.
Any suggestions? Thanks.
Old 11-05-2010, 09:50 PM
2002 F350V10's Avatar
2002 F350V10
2002 F350V10 is offline
is there a mute button?
Old 11-05-2010, 09:52 PM
vitaminj75mg
Yeah, but it wasn't engaged. I tried pushing it both in and out to no avail.
Old 11-05-2010, 09:56 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Run the radio self test. Hold down the 2 and 6 button at the same time it will pop up a dtc and a failure list. The radio must be on for this to work and the buttons 1 through 6 each one once in self test gets you into a sub program. So report back
Fordyarddog
2004 - 2008 F150
07-20-2016 03:21 PM
2qwk
05-20-2016 12:43 PM
wrhatt
03-30-2016 06:34 PM
Ultimate4x4
12-23-2012 07:13 PM
darag5
1997-2006 Expedition & Navigator
08-05-2011 05:41 PM
Quick Reply: 2005 F350 Radio Problem
