serpentine belt recommendations
What brand belt do you guys/gals recommend?
My truck had a NAPA belt when I bought it, after a few months it stated squeeling. I replaced it with a belt from Advance auto, it lasted a day before it shreaded. They gave me a new one, and it also shreaded after a few months leaving me stranded in BFE.
I then bought another NAPA belt (only parts store for miles) and yesterday it started squeeling again real bad after I hosed off the engine.....
I forked over $58 for a Gates Green Stripe belt from O' Rileys. (It was their best belt with a 1 year warrenty)
Did I just waste more money? So far (today) its been a very quiet belt.
I clear it up for you...
OEM BABY!
Pop has the right advice about checking things. Napa and Carquest both sell Gates belts as their private label. If all your belts are squeaking, something else is going on.
I'd suggest you inspect your new belt now for any signs of wear before you have problems with the new one.
I even tried a can of belt conditioner to stop the squeel, and it just changed the tone on the noise.
Do you think the actual tensioner spring could be the problem? The last belt that shredded happened right as I floored it to pass someone.
Frank, When my tensioner started to go out I was seeing deflection in the belt between the alternator and power steering pump. Then when it was on it's last leg it started to make a loud clanking sound. Good chance yours has never been changed out and probably a good idea. You can look at the gap in the tensioner and make sure that it is even. Don't take apart the old one they are spring loaded and may cause bodily harm.. I was going to take mine apart until I read the warning on the directions. I have a gator belt and OEM as a spare.....:
I shreded one belt after another it ended up being the power steering pump. When I hit the brakes hard the pump was looking up due to a failure in the pressure spring from the hydroboost and causing the belt to spin and cut through the sharp ridges on the pulley. Just a thought.
