Maryland Chapter Join Chapter, Leader: BPofMD
Coolant Leaking
Old 11-23-2010, 06:00 AM
Blade79's Avatar
Blade79
Blade79 is offline
Coolant Leaking
Hey guys. Got a little issue. I started the truck last night to let it run since I havent driven it in a while and I noticed it was running a little rough. Was thinking it was cold and just needed to run a bit but I poped the hood anyway and looked around. Found a puddle of coolant behind the water pump by the distributor. Didn't see any of the hoses leaking so I'm thinking it must me the gasket on the water pump?? It looks like the previous owner had replaced it and had used that gasket maker stuff instead of buying a regular gasket. Could this be the issue or could it be something else I am missing?
Old 11-23-2010, 10:34 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,101 Likes on 1,001 Posts
If it isn't the gasket, look to see if it's leaking out the "weep hole" on the bottom of the pump. Either way, it's gotta come off......but that in itself shouldn't make it run rough.....
Old 11-23-2010, 01:20 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
look up by the throttle body, on the left. there is a small,3/8 hose that comes from a metal line.it comes in from the top, and goes back out of the bottom. is actually 2 lines to make up a heater to the throttle body. check that it is not rotten, and broke from all the work you did lately. this hose is not available now, so just cut it and use fuel line.
Old 11-23-2010, 05:24 PM
jr32560's Avatar
jr32560
jr32560 is offline
either like the others said or the intake manifold
chillman88
General Automotive Discussion
12-30-2013 08:39 PM
BruceJeremy
1997 - 2003 F150
12-23-2012 05:26 PM
dpoc
1983 - 2012 Ranger & B-Series
10-14-2012 07:39 PM
BrianA
1997 - 2003 F150
17
01-06-2005 07:04 PM
nictic
07-11-2004 10:51 PM
Quick Reply: Coolant Leaking
