1990 250 7.3 IDI Shut off wont restart Bad Injector Pump?
180K
Had the truck towed back in. So far i have Checked the following.....
Fuel Flow Before the filter housing and fuel flow After. I get a Healthy Spurting Stream when the motors turns over.
Check the Solenoid in the Injector Pump..getting power and it is clicking.
I dont think the truck has elec fuel pump...Just the Mechanical on the Engine block correct?
however i am getting No fuel from the injector lines so im taking the pump to a Shop that has a Flow bench to tell if it is shot and for a possible rebuild.
So am i missing anything?
Also what is the sensor in the Injector Pump Housing? 2 wire switch.
ernesteugene
25
03-01-2021 07:43 PM
gov2mod
46
02-17-2019 01:26 AM
mastermidnight
17
11-18-2016 06:57 PM
big ole ford
02-27-2014 09:46 PM
