1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 6.0L oil pressure switch leaking
Old 10-31-2010, 10:47 AM
bfnavarrete's Avatar
bfnavarrete
bfnavarrete is offline
I have a 6.0L F-350 6.0L PSD with 265,000 miles. The truck started leaking/spilling oil between engine and bell housing on passenger side. i found the leak to be coming from the oil pressure switch so i replaced it. 1 day later, the truck started to drip and by the end of the day turned into a leak/spilling of oil. thinking that it could of been a faulty part, i replaced the switch again. again, 1 day later a small drip formed and quickly turned into a leak/spilling of oil. all gauges read fine and the oil pressure reads normal.
Have y'all had this problem before? could there be an intermittent problem causing the switch to fail?
Thanks in advance
Old 10-31-2010, 08:10 PM
bfnavarrete
anyone??? ttt
Old 11-05-2010, 09:12 PM
2001 bolt's Avatar
2001 bolt
2001 bolt is offline
the reason the oil pressure switch keeps failing is due to oil contamination that is still in the connector end...make sure you clean all of the oil out of the connector and whipe it clean and make sure you dont spray any cleaner on the new sensor as they are pretty delicate and will just keep leaking...hope this helps
Old 11-05-2010, 09:29 PM
6litremachine's Avatar
6litremachine
6litremachine is offline
replace the connector end too... rather than cleaning it, they're relatively easy, they are stocked by most ford dealers, and not too expensive. be sure to put the silver wire loom back on to protect from heat.
Old 11-05-2010, 09:39 PM
djanzen's Avatar
djanzen
djanzen is offline
Where is this switch? the pressure switch for the 6.0 is in the oil cooler at the front of the engine on top?
xarons21
12-23-2020 09:12 AM
FORDF250HDXLT
03-26-2017 01:42 PM
mjflynn101
11-20-2016 06:37 PM
Kerly
09-17-2016 01:18 AM
F350FordToy
20
02-11-2016 04:49 PM
Quick Reply: 2004 6.0L oil pressure switch leaking
