help!!! truck wont start
#31
#33
well i havent been able to start my freaken truck and its gettin on my nerves. i have been scanning it with a snap-on modis scanner and the data shows 0 on the ipc, should it be like this or should it show different when i crank it. does this mean the used pcm i put in is no good? i have changed the ipc with a couple of used ones but still nothing.
#34
#36
#42
Where is shooter when you need him ?...
We may have to hook you up with a gauge to verify the IPR , then we can rule out a few electrical items . The PCM & IDM both need to be verified as good , since they were replaced. Or they need to be installed in another PSD ,(one component at a time) to see if they are any good . ...
To OP , have you tested all of the fuses & Relays in the power distribution box?
Have you( carefully) tested for 12 volts at the IPR ( key On ) A test light will do ...You can do it at the main harness on the rt side of the fuel bowl too (main 12 harness) .
#45
Had to re-read the post.....
So, a new CPS,
PCM came from a "known" working truck?
IDM apparently buzz checked good...
I would go the 0-5000psi gauge route and dead head the HPOP to verify that #1) IPR is working or intermittent or stuck/bad...and #2) confirm HPOP is good.......before I spend time and money on a HPOP.
Gauge set-up may cost $60.00 and a day's time, but you'll have it for ever.
But at this point, need to Confirm/verify without a doubt, what's working.
...I take it the engine was working fine, until the PCM/Chip removal? if so, I doubt the HPOP failed at the same time...
So, a new CPS,
