1995 F150 4X4 transmission ID
Old 10-27-2010, 05:34 PM
subsailor's Avatar
subsailor
subsailor is offline
Brand new member here--thanks in advance for any help. I have a 1995 F150 4X4 Eddie Bauer with auto tranny. I'm trying to determine what transmission I have. The tag on the transmission is unreadable. The emmissions controls tag lists it as code E. I suspect it is a E40D. What's the difference in a AOD, C6, and E40D? I need to replace the pan gasket and am trying to determine the fluid quanity.
Thanks, Bob
Old 10-27-2010, 05:46 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
This decoder should help you out: Ford Door Sticker Decoder .: Articles
I also like this photo for the pan shape and number of bolts:
Old 10-27-2010, 05:59 PM
subsailor's Avatar
subsailor
Thanks rla, the decoder posting and 20 bolt pattern helped determine that is was E40D, but I'm still wondering what the physical and mechanical difference in in an E40D, C6, and AOD is?
Old 10-27-2010, 06:06 PM
rla2005's Avatar
rla2005
E4OD is an electronically controlled 4 speed overdrive transmission. The C6 is a mechanical 3 speed transmission. An AOD is a 4 speed overdrive transmission that is also mechanically controlled.
The E4OD would require some type of electronic controller if was installed in a vehicle that did come from the factory with one. The C6 is controlled via a vacuum modulator and control linkage attached to the throttle. The AOD also uses a cable/linkage attached to the throttle to control the internal pressure.
More good reading here: Ford Transmission Spotter's Guide .: Articles
Old 10-27-2010, 06:19 PM
subsailor's Avatar
subsailor
Thanks, rla. You obviously know your shizz. I'll do some reading.
Old 10-27-2010, 07:38 PM
rla2005's Avatar
rla2005
BTW...Welcome to FTE!
crossy
12-02-2016 09:10 PM
pilot47
10-06-2015 06:51 PM
rubberman56
04-02-2015 02:52 PM
Stallion 429
01-17-2014 08:53 PM
southcoast
06-08-2011 02:03 PM
Quick Reply: 1995 F150 4X4 transmission ID
