gm 14 bolt swap done!!
#32
ok, so WHAT YEARS 14 blt would work? I have a D70 in my F350 right now but it has a scored spindle from a seized bearing...(just found it...PO must have chizzled off the old bearing and put a new one on just to sell it!) So now I am in his debate. I have been all over the wrecking yards and only found 1 D70....and at the time I didnt know about the scored spindle!
I have a '96 Suburban 2500 with a FF 14blt and I like it for the fact that the drums slide off WITHOUT removing the axle...but YES it is a FULL FLOATING 10.5" 14blt.
#33
#34
#35
#39
If its chewed you'll prob have high and low spots. Use a caliper and a bearing and just keep checking diameter as you clean it. Try sliding bearing on until its smooth. Use hardly no pressure, let the wheel do the work.
It would be better to judge from a pic if its salvageable but its not like its an engine bearing. Use your judgement.
boggin79ford
83
09-09-2016 06:29 PM
shanes66charger
81
05-25-2016 02:49 PM
Brandon Harrison
34
04-13-2014 12:17 AM
boggin79ford
17
04-07-2013 10:04 PM
