6 cylinder BLOCK casting number, WHERE?
Old 10-23-2010, 09:06 PM
Eston Newbern's Avatar
Eston Newbern
Eston Newbern is offline
Trying to find WHERE these mumbers are to I.D, for parts etc, any help appreciated.
Old 10-24-2010, 09:52 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Eston Newbern
Trying to find WHERE these numbers are to I.D, for parts etc, any help appreciated.
This is the second thread where you've asked this question. I gave you the answer in your other thread, here it is again.
Since you have a 1965 F100 (you failed to mention this-I got the info from your profile), you have either a 240 or 300 I-6.
The SAME block was used for both, so you will have to measure the stroke to find out which I-6 it is. 240 = 3.18" / 300 = 3.98"
Casting numbers on engine blocks are foundry marks, which are usually useless in ID'ing engine sizes, since they cannot be cross referenced to Ford part numbers.
The same scenario applies to most FoMoCo OHV V8 engines from 1952 thru the 1970's.
JohnnyMarauder
2017+ Super Duty
02-28-2017 11:25 AM
Mikerod
02-03-2017 05:18 AM
hanklin
21
07-26-2016 09:54 AM
dj lpm
2015 + Expedition & Navigator
04-15-2016 12:31 AM
cajunsf
1978 - 1996 Big Bronco
05-28-2006 11:44 AM
Quick Reply: 6 cylinder BLOCK casting number, WHERE?
