Be careful when wireing B.U. lites.
If you have an switch that turns them on when in reverse and pick the power from the ign. side of switch so they won't be on in acc. position then if you put it in rev. before shutting engine off and you forgot you had the override (cargo/ loading switch) on which will be fed from a hot line it will feed back and keep the engine on with the ign. off!
I solved this with a relay.
Please someone tell me how to post pictures.
I hadn't seen this site for yrs, thought it had died. I was getting notices of new Fords like sales pitches. Guess I forgot how to get to this section?
Nice looking truck Walston
