1978 - 1996 Big Bronco
1990 Ford Bronco Starting Issue
Old 10-21-2010, 06:35 PM
Wicked Endings's Avatar
Wicked Endings
Wicked Endings is offline
Hello!
I have a 1990 Ford Bronco, Full Size, 4x4, 302 V8...
I also have a problem....
It won't start.
I couldn't figure it out, so I brought it to a mechanic.
At first, the truck would not even start to turn over.
The mechanic got this electronic plug-in part that plugged into the side of the distributor.
Then the truck started to turn over, but it would not start. However, it would only turn over when he had the battery charger on it. He said the battery was not holding a charge.
So we went and got a new battery.
Plugged in the new battery, and now the truck turns over, but it still doesn't start.
I said it wasn't getting any spark. The mechanic had this thing and said it was.
So! Now I am sitting here trying to find out why it won't start.
Any ideas?
Also! Right before the starting problem, the running lights in the back stopped working. The turn signals, brake lights, and backup lights all work. But the lights that turn on at night don't. All of the front lights work, just the back running lights do not.
The day before the lights stopped working, we replaced a head gasket. I wasn't there, but nothing looked like it had been messed with...
SO!
I need help!
Old 10-21-2010, 07:40 PM
MidnightsSpark's Avatar
MidnightsSpark
MidnightsSpark is offline
Maybe its mad at you.
Old 10-21-2010, 07:47 PM
vtjvt's Avatar
vtjvt
vtjvt is offline
Has it ran since you replaced the head gasket? Also your mechanic said it is getting spark, how about fuel? If it hasn;t run since the head gasket (and even if it has) check the distributer. Make sure it is installed correctly and the timing is right.
For your Tail lights Does your dash lights work? check all your fuses
Old 10-21-2010, 08:01 PM
C. McAuley's Avatar
C. McAuley
C. McAuley is offline
4wd High
HI, It sounds like a fusible link is blown , they should be on the solenoid switch. With rubbery tag indicating the wire gage. If one of these has blown you might not be getting 12 vote power to the on board computer. I would check there first. P.S. if you pull on one at a time, and one stretches like an elastic Bingo you fond the problem. Have a good Day and good luck. Cliff
2011F150v8
2009 - 2014 F150
06-25-2017 01:24 PM
BigCat17
10-27-2016 06:56 AM
coletr2
02-24-2016 09:42 PM
echarter
01-10-2016 04:07 PM
f150on.
10-26-2015 05:54 AM
Quick Reply: 1990 Ford Bronco Starting Issue
