Thank you, its a 4bbl. Anyway to tell the GVW or unladen weight with a missing plate?
The only thing I can tell you since the Warranty Plate is missing is that F600's of this vintage will have a GVW between 14,000-20,500 lbs.
Call Ford's 800 number, pass along your VIN and request a copy of your trucks original build sheet...there is no charge. Expect an answer in 2-4 weeks.
