removing leafs from F5 springs
While I am not using my F5 on a regular basis yet, I have had the opportunity to drive it around town and at a couple of shows over the past month. The bouncing and banging is being addressed one thing at a time. First was replacing the cab mount bushings and bolts (the old rear mounts had been installed upside down). Next was replacing the dove tail bushings and the striker plates.
The banging is about gone, but the bouncing and jarring about scared the wife right outta the truck. The old steel flatbed is long gone and the new wood stake bed is 'in the process' in the shop. Before I start building the bed on the truck I am considering removing some of the 12 leafs (each side) on the rear.
I'm thinking about removing every other leaf and then leaving the helpers in, 'just in case'. The new bed I am estimating will weight between 800 and 1000 lbs. and it will probably never see any kind of load on it.
The question I have is, how big of a job is this on this size truck, or should I suck it up and take it to a spring shop?
I might be wrong, but I doubt you'll see the same softening of the ride that you would on an F1. The springs on the big trucks are bigger and stiffer - and if it does work it might throw the little lady around even more than stock.
The stock seat is pretty well sprung if you can remain in place - I'd opt for seatbelts before changing the springs.
