Edelbrock 94-Series Two Barrel Carburetors
An industry original is back, only this time it carries the Edelbrock name. Edelbrock is pleased to introduce the Edelbrock 94, an all-new two-barrel carburetor based off the original Chandler-Groves design. It is intended to provide a bolt-on performance solution for nostalgic and period correct hot rods and restorations. The Edelbrock 94 features die-cast bowl and air horn with a cast iron 3-bolt flange. Its throttle shaft has been extended to make it easier to set-up dual and triple carburetor combinations, especially when used with Edelbrock”˜s exclusive progressive linkage. Extensive testing, both on the road and in our state-of-the-art engine dynamometer facility has allowed Edelbrock to fine tune power valve and jetting combinations to deliver smooth and strong performance. It is finished off with a zinc-dichromate coating for durability and classic looks. A host of accessory items will be available to complement these carburetors, including: round chrome air-cleaners (#1202); progressive throttle linkage kits, dual (#1032) and triple (#1034); straight throttle linkage kits, dual (#1032) and triple (#1034); and mini fuel blocks (#1286).
Features Include:
- Brand new, based off of the original Chandler-Groves design
- Extended throttle shaft for easy installation on multiple carb set-ups
- Period correct appearance
- Optional accessories and complete induction kits (coming soon)
- Applications include: Primary carb (#1151); Secondary carb (#1152)
For more information visit www.edelbrock.com
About Edelbrock
Founded in 1938, Torrance-based Edelbrock Corp. is recognized as one of the nation’s premier designers, manufacturers and distributors of performance replacement parts for the automotive and motorcycle aftermarkets.
