2011 Ford F-Series Super Duty Specs
By -
Powertrain/ChassisF-250/350/450  |  F-350/450/550
Dimensions/CapacitiesF-250/350/450  |  F-350/450/550
F-250/350/450 Powertrain/Chassis
POWERTRAIN
6.2L 2V V-8
6.7L 4V V-8
Engine type
SOHC EFI Gas (Flex Fuel)
OHV Power Stroke® Turbo-Diesel
Block/head
Iron block, aluminum heads
CGI/aluminum
Bore/stroke
4.02 x 3.74 in
3.90 x 4.25 in
Displacement
379 cu in, 6,210 cc
406 cu in, 6,651 cc
Compression ratio
9.8:1
16.1:1
Fuel injection
Sequential multi-port
Common-rail piezo
Valvetrain
SOHC, 2 valves per cylinder, variable cam timing
4 valves per cylinder, pushrod with individual hydraulic lash
Power
N/A
 N/A
Torque
N/A
N/A
Oil capacity
7 quarts
13 quarts
Coolant capacity
25.7 quarts
28.4 quarts
Fuel capacity
35 gallons
37.5 gallons (158-inch and 172-inch WB) / 26 gallons
(137-inch, 142-inch and 156-inch WB)
Transmission type
Six-speed SelectShift Automaticâ„¢ with Tow Haul Mode
Six-speed SelectShift Automatic with Tow Haul Mode
SUSPENSION
Front
4×2
Independent twin I-beam (narrow front track) with coil springs, shock absorbers, stabilizer bar (F-250/350)
Mono beam (wide front track) with coil springs, shock absorbers, stabilizer bar (F-450)
4×4
Mono beam (narrow front track) with coil springs, shock absorbers, stabilizer bar (F-250/350)
Rear
4×2
Non-independent live axle with leaf springs, staggered shock absorbers and stabilizer bar;
stabilizer bar standard on DRW models and available with camper package and snowplow package on SRW pickups
4×4
BRAKES
Front
13.66-inch discs (F-250, F-350), 14.53-inch discs (F-450)
Rear
13.39-inch discs (F-250, F-350), 15.35-inch discs (F-450)
Assist type
Vacuum (F-250/F-350 SRW gas engines) / hydro-boost (F-350 SRW diesel engine, F-350 DRW F-450), ABS
WHEELS AND TIRES
Base wheels
and tires
17-inch steel on F-250/F-350 SRW and F-350 DRW; 18-inch cast aluminum on F-250/350 SRW;
17-inch forged aluminum on F-350/F-450 DRW
Largest tires available
20-inch aluminum wheels, LT275/65R-20E
F-250/350/450 Dimensions and Capacities
Regular Cab
SuperCab
Crew Cab
8-ft
6.75-ft
8-ft
6.75-ft
8-ft
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
EXTERIOR
Wheelbase
137.0
137.0
141.8
141.8
158.0
158.0
156.2
156.2
172.4
172.4
Overall length
227.6
227.6
262.4
232.4
248.6
248.6
246.8
246.8
263.0
263.0
Overall height
76.5
(76.7 for DRW)
80.0
(79.5 for DRW)
77.0
79.5
76.7
(76.9 for DRW)
80.2
(99.7 for DRW)
77.4
79.7
77.2
(77.3 for DRW)
80.8
(79.9 for DRW)
Cargo box length @ floor
98.0
98.0
81.8
81.8
98.0
98.0
81.8
81.8
98.0
98.0
Cargo width between wheelhouse
50.9
50.9
50.9
50.9
50.9
50.9
50.9
50.9
50.9
50.9
Inside box height
20.0
20.0
20.0
20.0
20.0
20.0
20.0
20.0
20.0
20.0
INTERIOR
Seating capacity
Two/three
Two/three
Five/
six
Five/
six
Five/six
Five/six
Five/six
Five/six
Five/six
Five/six
Headroom
Front
40.7
40.7
40.7
40.7
40.7
40.7
40.7
40.7
40.7
40.7
Rear
38.1
38.1
38.1
38.1
40.8
40.8
40.8
40.8
Legroom
Front
41.1
41.1
41.1
41.1
41.1
41.1
41.1
41.1
41.1
41.1
Rear
31.6
31.6
31.6
31.6
42.1
42.1
42.1
42.1
Hip room
Front
67.6
67.6
67.6
67.6
67.6
67.6
67.6
67.6
67.6
67.6
Rear
67.3
67.3
67.3
67.3
67.6
67.6
67.6
67.6
Shoulder room
Front
68
68
68
68
68
68
68
68
68
68
Rear
68.1
68.1
68.1
68.1
68
68
68
68
Turning diameter, curb-to-curb (ft)
47.7
46.1
49.1
47.5
54.1
52.3
53.6
51.8
58.5
56.6
All dimensions in inches unless otherwise noted.
F-350/450/550 Powertrain/Chassis
POWERTRAIN
6.2L 2V V-8
6.7L 4V V-8
6.8L 3V V-10
Engine type
SOHC EFI modular gas (Flex Fuel)
Block/head
CGI/aluminum
Bore/stroke
4.02 x 3.74 in
3.90 x 4.25 in
3.55 x 4.17 in
Displacement
379 cu in, 6,210 cc
406 cu in, 6,651 cc
414 cu in, 6,783 cc
Compression ratio
9.8:1
16.1:1
9.2:1
Fuel injection
Common-rail piezo
Valvetrain
SOHC variable cam timing
4 valves per cylinder pushrod
3 valves SOHC hydraulic lash adjuster with roller follower
Power
N/A
N/A
N/A
Torque
N/A
N/A
N/A
Oil capacity
7 quarts
13 quarts
7 quarts
Coolant capacity
25.7 quarts
29.4 quarts
26.7 quarts
Fuel capacity
40 gallons (SRW with Payload Package and all DRW) / 28 gallons (SRW with base payload)
40 gallons (SRW with Payload Package and all DRW) / 28 gallons (SRW with base payload) / both tanks available for DRW
Transmission type
with Tow Haul Mode (F-350)
with Tow Haul Mode (all)
Five-speed automatic O/D SelectShift     (F-450 and
F-550 only)
SUSPENSION
Front
4×2
Twin I-beam (F-350), mono beam (F-450/F-550) with coil springs, shock absorbers and stabilizer bar
4×4
Mono beam (F-350, F-450/F-550) with coil springs, shock absorbers and stabilizer bar
Rear
4×2
Non-independent live axle with leaf springs, shock absorbers, stabilizer bar
4×4
Non-independent live axle with leaf springs shock absorbers, stabilizer bar
BRAKES
Front
13.66-inch discs (F-350), 14.53-inch discs (F-450/F-550)
Rear
13.39-inch discs (F-350), 15.35-inch discs (F-450/F-550)
Assist type
Vacuum (F-350 SRW gas engines) / hydro-boost (F-350 SRW diesel engine,
F-350 DRW, F-450/F-550), ABS
WHEELS AND TIRES
Base wheels
and tires
17-inch steel on F-350 DRW, 18-inch aluminum on F-350 SRW, 19.5-inch aluminum (F-450/550)
LT245/75Rx17E (F-350 DRW), LT275/70Rx18E (F-350 SRW), LT225/70Rx19.5G (F-450/550)
F-350/450/550 Dimensions and Capacities
Regular Cab
SuperCab
Crew Cab
EXTERIOR
Wheelbase /
Back-of-cab-to-axle
140.8/60
164.8/84
188.8/108
200.8/120
161.8/60  185.8/84
176.2/60
200.2/84
Overall length
226.5
250.5
274.5
286.5
247.5  271.5
261.9
285.9
INTERIOR
Seating capacity
Two/three
Two/three
Two/three
Two/three
Five/six
Five/six
Five/six
Headroom
   Front
40.7
40.7
40.7
40.7
40.7
40.7
40.7
   Rear
38.1
40.8
40.8
Legroom
   Front
41.1
41.1
41.1
41.1
41.1
41.1
41.1
   Rear
31.6
42.1
42.1
Hip room
   Front
67.6
67.6
67.6
67.6
67.6
67.6
67.6
   Rear
67.3
67.6
67.6
Shoulder room
   Front
68.0
68.0
68.0
68.0
68.0
68.0
68.0
   Rear
68.1
68.0
68.0
Turning circle,
curb-to-curb
(F-450/550) (ft)
42.3
48.6
54.8
57.9
47.8  52.4
51.5
57.8
How to Guides
View All >
Twin Turbocharged 1971 Ford F-100 Looks Rough, Goes Like Hell
Slideshow: A seriously quick, heavily patina'd vintage hauler.
Read It
The 10 Best Values in the 2024 Ford Truck & SUV Lineup
Slideshow: We pick the best values in the 2024 Ford truck & SUV lineup.
Read It
Four Ford Trucks Take Home ‘Best Value’ Awards for 2024
Slideshow: Based on a cost of ownership analysis.
Read It
1961 Ford F-100 Was Rescued From Scrapyard, Turned Into Awesome Restomod
Slideshow: Facing certain death, this old Ford truck has found a new life as a valuable restomod!
Read It
