08/27/2003 – 2004 F-150 Television Commercial Transcripts
Source: Ford Motor Company |
2004 F-150 TELEVISION COMMERCIAL TRANSCRIPTS
America’s Truck A truck like this isn’t built in a factory. It’s built in the farms and fields. Concrete streets and crowded construction sites that map the landscape of an entire country. Because when Ford builds the new F-150, there are promises to keep. And only one truck earned the right to be the next F-150. If you haven’t looked at Ford lately, look again. Power Trip We didn’t just give the new Ford F-150 more horsepower. We gave it the most low-end torque. Why did we push farther than anyone else? So you could do more than anyone else. Only this truck earned the right to be the next F-150. If you haven’t looked at Ford lately, look again. Twists & Turns Only one truck has crossbars that are welded through the side rails. That truck is the new Ford F-150. It has the strongest, toughest frame of any full-size pickup. Which also gives you the highest payload. Only this truck earned the right to be the next F-150. If you haven’t looked at Ford lately, look again. Quiet Time We engineered a material behind the dash called Quiet Steel. Only the new Ford F-150 has it. Which means it’s the only truck to deliver this: the sound of quality. The sound of the quietest pickup. Period. Only this truck earned the right to be the next F-150. If you haven’t looked at Ford lately, look again. |
