• Recalls
  • Technical Service Bulletins (TSBs)
FORD Technical Service Bulletins
Check for technical service bulletins (TSBs) on your vehicle by make, model, and year.
Frequently Asked Questions - FAQ
What is a Technical Service Bulletin?
A Technical Service Bulletin (TSB) is a document that identifies an unanticipated vehicle or part issue and provides a solution. There can be more than one TSB for the same issue if different technicians or engineers have figured out different solutions. A TSB may be provided to dealerships, sent to auto repair shops, or sent out to vehicle owners, depending on the range and scope of the problem.
What is the difference between a Recall and a Technical Service Bulletin?
While a recall concerns a safety issue which must be fixed, a Technical Service Bulletin just identifies a common issue and documents a solution. The difference is that manufacturers are not required to make the repair at no cost for a problem documented in a TSB. However, the circulation of the bulletin amongst dealerships and manufacturers can help diagnose the issue and lead to faster and more efficient fixes.
Do I have to pay or will the manufacturer pay for the TSB related repairs?
Dealers and manufacturers are not required to pay for a repair indicated in a TSB since the issue is not identified as posing a safety concern. There may be repairs that a manufacturer agrees to pay for, however, particularly if the repair has the potential to cause a class-action lawsuit for the manufacturer, and these notifications evolve from a TSB into a "service campaign" or "service warranty".
How do I find out if a TSB has been issued for my vehicle or part of my vehicle?
The Technical Service Bulletin tool on this site can be used to determine if there are outstanding TSBs on your vehicle. Simply select by vehicle year, make, and model.
FORD Recent Technical Service Bulletins
  • FORD F-150
    118000 ELECTRICAL SYSTEM: SOFTWARE
    RECORD_ID: 4644838
    Bulletin Number: SSM 52343
    Replacement Service Bulletin Number: N/A
    NHTSA Item Number: 10251960
    Date Posted: 03-08-2024
    Component Name: 118000 ELECTRICAL SYSTEM: SOFTWARE
    Make: FORD
    Model: F-150
    Year: 2024
    Date Added: 03-20-2024
    Summary: Some 2024 F-150 vehicles may exhibit no audio output when using Spotify. Audio output may recover with a key cycle. This may be due to the accessory protocol interface module (APIM) software. Replacement or reprogramming of the APIM will no
  • FORD F-150
    RECORD_ID: 4644820
    Bulletin Number: SSM 52345
    NHTSA Item Number: 10251956
    Make: FORD
    Model: F-150
    Year: 2024
    Summary: Some 2022-2024 various Ford/Lincoln vehicles equipped with SYNC 4 may experience concern where customers are receiving an error message when trying to enroll in connected services. This may be due to the gateway module (GWM) software. To co
  • FORD F-150
    RECORD_ID: 4644805
    Make: FORD
    Model: F-150
    Year: 2023
  • FORD F-150
    RECORD_ID: 4644790
    Bulletin Number: SSM 52344
    NHTSA Item Number: 10251955
    Make: FORD
    Model: F-150
    Year: 2024
  • FORD F-150
    046100 SERVICE BRAKES, AIR: ANTILOCK: CONTROL UNIT/MODULE
    RECORD_ID: 4644785
    Bulletin Number: SSM 52340
    NHTSA Item Number: 10251953
    Date Posted: 03-06-2024
    Component Name: 046100 SERVICE BRAKES, AIR: ANTILOCK: CONTROL UNIT/MODULE
    Make: FORD
    Model: F-150
    Year: 2023
    Summary: Some 2023 F-150 Raptor/Tremor vehicles may exhibit failed programmable module installation (PMI) using the Ford Diagnosis and Repair System (FDRS) when installing a new ABS module. This may be due to the software within the new ABS service
