Big Blue '94 Ford Bronco Looks Like Loads of Fun
Daily Slideshow: Simple, attractive, and loaded with fun, this '94 Ford Bronco deserves all the attention we can give it.
Making a Name
While they haven't quite received the feverous attention bestowed upon the first and second-gen Broncos, models from the '90s are steadily growing in popularity. Once famous mostly because of a certain low-speed police chase, these slightly rounded Broncos are now appealing to us thanks to their inherent simplicity and handsome looks. And this beautiful blue '94 we spotted at 4-Wheel Classics has all of those attributes and more.
Rot Free
Finding a rusty Bronco of any vintage is pretty easy to do. But this particular 'ute has zero rot after living its lived in dry and arid Nevada. Even the paint is mostly original, save for a respray of the hood and roof where the desert sun did some damage.
>>Join the conversation about this 1994 Bronco right here in the Ford Trucks Forum!
Colorful Combo
There are a few stone chips here and there, of course. But nothing you'll see from a few feet away. Otherwise, we're certainly digging that attractive blue and white color combo that just looks cool, even today.
Killer Stance
To give this old Bronco a killer stance, a 4-inch suspension lift has been added. The previous owner then threw on a set of beefy 33-inch tires to fill up that newfound space and finish off the look.
Just Right
Overall, this Bronco sits just right with those simple modifications. Almost like it should have come this way from the factory, without going too big like many folks do.
Stopping Power
The brake lines were replaced with stainless steel pieces guaranteed to stand the test of time, even if this Bronco never sees road salt. But other than that, it's mostly stock everywhere else.
Nice Options
This clean Bronco does sport some nice factory options, however. They include goodies like power windows and locks, a power rear window, air conditioning, tilt steering wheel, and cruise control.
Effortless Cruiser
Under the hood, you'll find a good old tried and true 351 Windsor V8. The 5.8-liter motor is backed up by an automatic overdrive transmission for effortless highway cruising.
Clean and Comfy
The interior of this big blue Bronco is just as clean as the outside, with plenty of blue cloth to keep you comfy on road trips. Everything inside also reportedly works perfectly, down to the very last light bulb and switch.
Value Proposition
You'd certainly be hard pressed to find a much nicer example of a '90s Bronco than this. And since they're much cheaper to buy than earlier gens, you get all the goodness Broncos have to offer without having to take out a second mortgage!
For help with your maintenance and repair projects, please visit our How-to section in the forum.
