7 Other Uses for the Coin Holder in Your Ford Truck
Check out the better ways to use the coin holder in your Ford.
Don't Let the Coin Holder Space Go to Waste
Ford truck enthusiasts agree that the vertical coin holder in their trucks is a pretty useless feature. On 4x4 models, this space is where the 4x4 switch is kept, but for trucks without 4x4, it’s clear the potential usage of this space wasn’t very thought out. Many Ford-Trucks.com forum members confirm that it doesn’t do a good job at holding coins in place at all, causing them to rattle around or fall onto the floor as they drive normally. Here are seven ways to make better use of the coin holder if you haven’t got a 4x4 switch there.
1. Push Button Start
You may have to do some trimming once you find a fitting that will hold the push button securely in place, and complete some wiring to get it set up, but this is a worthwhile weekend project that will make much for better usage of the space.
2. Transmission Temp Gauge or Volt Meter
If you tow loads often, then a transmission temperature gauge is a convenient gadget to have right there in your field of vision while driving. Similarly, you can find volt meters that will fit perfectly into the coin holder hole. To supply power, you’ll need to run a wire to the battery.
3. Custom Light Switches
If you’re nifty, you can fashion a holder to house light switches for off-roading or other custom lights you add to your truck.
4. Mute Switch for Radar Detector
If you’ve got a radar detector, you can install a mute switch or button for it in place of the coin holder. Having this switch in close proximity to where your hands already are while driving will make muting the detector more convenient.
5. HAM Radio
If you’ve got your HAM license (for amateur radio operating), why not utilize the coin holder space to install a HAM radio? You can find a guide to installation on Ford-Trucks.com by clicking here.
6. USB Port
With so many on-the-go gadgets and accessories intended for usage in a car, it only makes sense to outfit your truck with additional USB ports if so desired. Gone are the days of fighting over the ports to charge your phone, or having to use a cigarette lighter adapter!
7. Cell Phone Holder
Don’t settle for simply throwing your expensive smartphone in the cup holder or in the center console. Attach a belt clip or insert a cell phone mount into the coin holder instead. Your phone will look better secured and will be easier to access this way.
What other mods have you done to your coin holder? Join the conversation here at Ford-trucks.com!
For information and maintenance guides, browse our technical how-to articles at http://ford-trucks.com/how-tos!
