Ford F-150/F-250: Sipe Your Tires How To
This simple tire modification can make your F-150 or F-250 perform considerably better in wintery conditions. Siping your tires make the tread more flexible and grippy in all off-road conditions. The best part? You don't need a tire shop (or any money) to do it.
By Justin Banner - September 29, 2014
This article applies to the Ford F-150 (2004-2014) and F-250, F-350 Super Duty (2005-2014)
While highway tires and all-terrain tires have siping from the factory, most mud tires do not have sipes in their tread blocks. That's fine if you only use them in mud. If you occasionally drive your F-150 or F-250 on the street, siping those tires will improve your handling at the cost of tire wear. We’ll briefly show you how to sipe the tread blocks and explain how and why it works.
There are two things you can do to your mud tires to increase traction; grooving and siping tires. Grooving involves removing full chunks of rubber from your tread blocks. Siping, on the other hand, is a process to cut a small relief in the tread block ninety-degrees at horizontal of the tire. You’ll barely notice that you’ve made the cut if you’ve done it right as you’re only just cutting a relief and not taking any more rubber out of the tread block.
Materials Needed
  • Hot knife
Step 1 - Warm hot knife
You can use a regular utility knife or a straight razor, but why make life harder? Make sure the one you use has enough of a handle that will make your cuts steady and gets hot enough to melt the rubber the knife blade hits, usually about 250 Watts is enough.
Figure 1. This is a "Hot Knife" or a "grooving iron."
Step 2 - Cut tread blocks
Cut the tread blocks at ninety-degrees horizontal of the tire tread, going across the block. You can cut multiple sipes into the block, but don’t get too overzealous. Do up to six on bigger lugs and two on the smallest ones. When you make the sipe, don’t go all the way through the tread block. Cut down to about 3-4/32-inch from the bottom of the lug, or 1/2-inch deep at most.
Figure 2. You might not be able to see the sipes clearly, but they're there. Sipes should split the tread blocks, not remove rubber.
Pro Tip
Don't sipe the outer lugs that are near the sidewalls. There is a risk of those lugs breaking and flying off (a phenomenon known as "chunking") since they do flex the most from turning and movement in the sidewall over the road. You shouldn't really sipe them, but if you do, don’t make a cut all the way across.
Step 3 - Continue siping around tire
That’s all there is to it. Now you just have to do it the entire 31- to 42-inch circumference. Good luck and be safe while cutting!
Figure 3124. When you're done, your tire should look similar to this.
Featured Video: How to Sipe Your Tires
Related Discussions and Sites
