Ford F150: How to Install Step/Nerf Bars
Adding a step to your Ford F-150 makes it unique, and helps you get in and out of your truck. Read on to learn how to install it.
By Bassem Girgis - May 18, 2016
This article applies to the Ford F-150.
There is nothing like a rugged looking Ford F-150, and when it comes to looks, the exterior is where it's at. Adding a step bar to your Ford F-150 can give it a completely different and unique look, especially if the truck is lifted. Nerf bars are much more than a look modification, they assist you in getting in and out of your truck, which means you will be doing your knees a favor. If you decide to raise your truck, then adding steps is absolutely necessary, unless you like to jump that high every time you drive your truck. Luckily, adding a step is a bolt-on modification and can be done from the comfort of your own driveway. Read on to learn how to install a step or nerf bars to your Ford F-150.
Materials Needed
  • 13mm wrench
  • 13mm socket
  • Nerf bars
Step 1 – Align the nerf bars
The driver's side nerf bar would have the sharper curve on the back. Hook the bar on your rocker panel, and to ensure it's aligned properly, the bracket attached to your bar should go over the two holes—a small hole right on top of a big hole.
  • FORD F150 STEP NERF BAR DIY HOW TO REPLACE REMOVE CHANGE INSTALL
    Figure 1. Hook the bar in place.
    Figure 2. Align the holes on top of each other.
Step 2 – Install nuts
The bars come with special nuts that go through the hole, which allows you to screw your bolt right in place. Attach the nuts to the top holes, you will have to clip it through the bottom hole. Install the U-nuts onto all the holes.
    Figure 3. Special U-nut.
    Figure 4. Install nuts in place.
Step 3 – Tighten bar in place
For each bracket, there should be two bolts installed. One bolt goes into the U-nut you've installed, and the other bolt goes from the bottom up, and is attached to a washer and a nut. Install the two bolts on each bracket and tighten the bar down.
    Figure 5. Install bolts into U-nuts.
    Figure 6. Install bolts from the bottom.
Featured Video: Nerf Bars Install
Related Discussions
