Ford F-150/F-250: Off-Road Tire Reviews
Tires are made for a lot of different applications, so you need to make sure you choose the tire that's right for the off-roading terrain you love most.
By Pizzaman711 - November 4, 2014
This article applies to the Ford F-150 (2004-2014), and the F-250, F-350 Super Duty (2005-2014).
From the factory, your truck will normally come with street tires. These are best for the person who rarely sees anything but pavement, however, trucks aren't meant for pavement only. That's why you'll also see trucks with an off-road package come with all-terrain (A/T) tires as these offer a nice compromise between off-road capability and road manners. The more aggressive of a tire you choose, the further the road manners will be from a street tire. The factory tire size will vary with the year, trim level, 4x4, etc., however, as a general rule of thumb, two wheel drive trucks will come with around a 29-30" x 8.5-9.5" tire. Four wheel drive trucks will come with a tire of relatively the same width, but about 2-3" taller, which is important to note when changing tire size. Depending on how big the change is, as well as your gear ratio, you may have to change your gears to maintain the same performance you had before.
BF Goodrich Rugged Trail T/A
Firestone Destination A/T
Goodyear Wrangler AT/S
Cost Per Tire
$219
$228
$208
Estimated Tread Life
50-65k miles
40-60k miles
60-70k miles
Weight
43 lbs
52 lbs
50 lbs
Warranty
6 years, unlimited miles
5 years, 50k miles
Best Quality: Goodyear Wrangler AT/S
Best Value: Goodyear Wrangler AT/S
Cost per tire: $219
Estimated tread life: 50-65k miles
Weight: 43 lbs
Warranty: 6 years, unlimited miles
The Rugged Trail tires fall into that spot between a highway and all-terrain tire. It offers the performance you'd need for when you can't be on pavement, and the comfort you want when you are. These tires will ride a little rougher and be a bit louder than your highway tires, but the difference is small in most cases. Recommended if you're looking for off-road tires that are comfortable on the streets.
Cost per tire: $228
Estimated tread life: 40-60k miles
Weight: 52 lbs
Warranty: 5 years, 50k miles
These are a little closer to your standard all-terrain as far as performance and road manners go. The general consensus is you can find better tires for the money, however, they'll still perform well. The only real downside to these tires is the weight of them, as well as the performance when in heavy rain, but even then there's hundreds of worse tires you could be putting onto your truck. Recommended if you are looking for basic all-terrain tires.
Cost per tire: $208
Estimated tread life: 60-70k miles
Weight: 50 lbs
These are go-to tires in the truck community due to their long life, road manners, and performance in less than ideal conditions. For those who spend a lot of time on the road but still need to deal with that occasional muddy field or snowy driveway, these tires are perfect. Recommended if you're looking for performance tires on and off-road.
Back Roads
Toyo Open Country A/T II
Goodyear Wrangler Duratrac
Dick Cepek Trail Country
Cost Per Tire
$225
$196
$199
50-60k miles
50-70k miles
50-60k miles
Weight
50 lbs
45 lbs
52 lbs
Warranty
50k miles
6 years, 50k miles
Unlimited miles
Best Quality: Toyo Open Country A/T II
Best Value: Goodyear Wrangler Duratrac
Cost per tire: $225
Estimated tread life: 50-60k miles
Weight: 50 lbs
Warranty: 50k miles
Another go-to tire in the community, the Open Country A/T II provides everything you could want for those muddy roads and more. Whether you need to get across the farm, over a stream, or through the snow, these tires won't let you down. While these aren't dedicated mud/snow/rock tires, you'll be able to get through a good bit more than what you could with street tires. Recommended if you're looking for well rounded tires that will perform well in any condition.
Cost per tire: $196
Estimated tread life: 50-70k miles
Weight: 45lbs
Warranty: 6 years, 50k miles
These tires are popular among daily drivers, weekend off-roaders, and even commercial users for service trucks due to their reliability and performance. Another plus is their low weight and price tag. The low weight helps keep the truck from losing power, and the price difference between these and a comparable tire is similar to a free tank of gas. Recommended if you are looking for great quality tires for a lower cost.
Cost per tire: $199
Weight: 52 lbs
Warranty: Unlimited miles
The warranty on these tires alone sets them apart from the competition; with an unlimited mile, unlimited year term, you'll be covered as long as you keep them properly rotated. These tires aren't seen on the road as much because local tire shops most likely won't stock them, but they definitely won't disappoint. Recommended if you are looking for good tires with a great warranty.
Mudding
Federal Couragia M/T
Toyo Open Country M/T
Mastercraft Courser MXT
Cost Per Tire
$183
$321
$227
35-45k miles
50-65k miles
50-60k miles
Weight
53 lbs
65 lbs
62 lbs
Warranty
Prorated replacement
5 years
Best Quality: Toyo Open Country M/T
Best Value: Mastercraft Courser MXT
Cost per tire: $183
Estimated tread life: 35-45k miles
Weight: 53 lbs
Warranty: Prorated replacement
Without a doubt, these are the go-to mud tires when it comes to budget. You can't get better off-road performance for the price, but these are a cheaper mud tire. It won't have the road manners or the tread life as a more expensive mud tire, but if pavement is a rarity, then it shouldn't matter. These are ideal for those who are on a budget but still need good performance in the mud. Recommended if you are looking for less expensive tires.
Cost per tire: $321
Weight: 65 lbs
Warranty: 5 years
If you have the money to spare, the Toyo Open Country M/T's are ideal. These will give you the off-road performance you need, as well as the on-road performance you miss out on with other mud tires. Most mud tires are known to make road driving annoying due to the noise and poor road manners, however, these will ride on the road more like a traditional all-terrain tire. Recommended if you are looking for top notch tires and don't mind spending the money.
Cost per tire: $227
Weight: 62 lbs
The Mastercraft Courser MXT's are relatively new to the market and have the potential to become another one of the top mud tires. They offer great performance not only in the mud but in the snow as well. With the performance aside, they're still new to the market price point, which makes them a steal right now. It is highly recommend giving these a try as your next tire, especially if you want a tire few others have. Recommended if you are looking for performance tires at a lower cost.
Rock Crawling
Goodyear Wrangler MT/R with Kevlar
BF Goodrich Mud-Terrain T/A KM2
Super Swamper Irok
Cost Per Tire
$307
$400
$367
45-55k miles
30-45k miles
30-40k miles
Weight
54 lbs
60 lbs
64 lbs
Warranty
6 years prorated
6 years prorated
N/A
Best Quality: BF Goodrich Mud-Terrain T/A KM2
Best Value: Goodyear Wrangler MT/R with Kevlar
Cost per tire: $307
Estimated tread life: 45-55k miles
Weight: 54 lbs
Warranty: 6 years prorated
These tires are tried and true. Not only do they offer the great road manners you want when driving to your favorite crawling spot, they'll also give you the performance you need once you arrive. These tires don't have as strong of a sidewall as some of the other rock tires, but as long as you choose your lines carefully when aired down, you should be fine. Recommended if you are looking for great quality rock crawling tires.
Cost per tire: $400
Estimated tread life: 30-45k miles
Weight: 60 lbs
As aggressive as the KM2s look, they have pretty good road manners. They're loud but nowhere close to the sound of an Interco tire. They really shine off the road, and they're a great all-around trail tire. Whether that trail has you going through mud or snow or crawling rocks, these tires will be able to keep up. However, due to the aggressive tread, they're on-road performance in the rain will suffer. Recommended if you are looking for mainly off-road tires with minimum on-road driving.
Super Swamper Irok
Cost per tire: $367
Estimated tread life: 30-40k miles
Weight: 64 lbs
Warranty: N/A
If you're only crawling rocks, these tires should definitely be considered. What all Super Swamper tires lack in road manners they make up for in off-road performance. On the road, these tires are pretty bad. They're loud, hard to align, and ride rough, but on the rocks these tires will shine. They'll air way down but still maintain a strong sidewall to allow you to get across those rougher terrains. Recommended if you are only using them off-road.
Related Discussion
